5943 Discussions
difficulty regarding signal tap analysis
I do not know to use signal tap analysis simulink altera blockset which is used for dsp application.
can you please help me to use it.
Please clarify what you're trying to do. I could recap all the documentation on SignalTap, but imagine you're asking for something more specific(and I'm assuming you've already looked through the website and documentation on SignalTap). Note that most SignalTap users use it as a back-end tool for debugging. That means they don't put it in their design files, whether they be schematics, HDL, or Simulink files. They instead use at it as a design file(.stp) in Quartus that pulls signals from an already synthesized, and often already placed and routed, design. That being said, you may want to use it in your Simulink file in a manner similar to a scope, just in hardware rather than simulation. (I haven't done that myself, but am sure someone else can add their experience.) Anyway, could you elaborate more on what you're trying to do and what you've already tried(i.e. where you're getting stuck).
