16612 Discussions
Simulator assignments
I try to simulate a design with the QuartusII simulator. Some of the signals are however synthesised away. I connect the signals to output pins and use the "Implement as Output of Logic Cell", "Add to Simulation Output Waveforms" and "Preserve Fan-out Free Register Node".
Does the signal have to be available at top-level in order to preserve the signal during simulation?
It is test-signals on lower-level blocks, so I dont want to append the signal to the top-level.
Hope someone can help.
Morten
"Preserve Fan-out Free Register Node" should be all you need (no need to route the signal to the top level) if you are using a device family supported by this assignment.
From QII 7.2 on-line help:
--- Quote Start ---
Preserve Fan-out Free Register Node logic option
This option can be set in the Assignment Editor.
A logic option that specifies that the register should be preserved in the design even when it becomes fan-out free.
This option is available for supported device (Arria GX, Cyclone II, Cyclone III, HardCopy II, MAX II, Stratix II, and Stratix III) families.
--- Quote End ---
I have tried to put output pins on the lower-level blocks and set the Preserve Fan-out Free Register Node logic option without any luck. I also tried to look in the RTL viewer for the signal and assign the same option, but still the signals are no where to be found in the simulator.
I can only see them if I set the search option to "All name", but when I run the simulator they keep disappearing.
Any thoughts?
--- Quote Start ---
--- Quote End ---
It should not matter whether the signal you want to preserve goes to an output port of an entity/module. It is necessary that the signal be a register.
Now I found the problem. I mostly uses VARIABLES, but in order to use Preserve Fan-out Free Register it has to be SIGNALS.
Thanks for the help.
