hi group,
does somebody have any idea about nand flash controller to sram. regards babaLink Copied
Would you mind explaining what the "to sram" part means? Maybe if you provide more details about what you're trying to accomplish will make it easier for others to help you.
Hello.. I have successfully programmed and am able to read the values from nand flash. But after programming when i check the status whether it is successfully programmed or not, the status register shows there is some error in programming. This happens only when I enable ECC. If I disable the ECC it works cool!
Why is the status register showing that the programming is not successful?
