I just start to build my first project using this software. The top module has a function of counting pulse to 100 and then return to 0. To simplify it, I use two decimal counter named decimal to build it,
decimal m1(clk,en,ret,data,cout_mid),m2(cout_mid,en,ret,data,cout);
but the top module fails when synthesized. Errors listed below: Error (10228): Verilog HDL error at decimal.v(1): module "decimal" cannot be declared more than once
It’s really weird, can somebody help me? Thank u
I think, the error is in the design files overall strcuture, not shown in your post. I suggest to start with Verilog designs from the Quartus design templates to avoid simple syntax errors.
The error like this could appear if you add to your project two or more files that have inside description of decimal.v module.
thank u both, I have solved this problem. Using this software, there is no need to include the bottom module file, which will be recognized automatically.
Topic Options
