16619 Discussions
HEX Data item missing input file
Hay!
I have a problem to generate *.jic file with QUARTUS II version 7.1 (build 156 04/30/2007). An error was generated when I click generate button (see picture bellow).:confused: Of course I also try without memory map file selected.
Is this a bug of this version or I misunderstood something?
Primoz
PS: . I follow how to generate *jic file instructions from http://www.altera.com/literature/an/an370.pdf (http://www.altera.com/literature/an/an370.pdf) page 11. I successfully generate the file with QUARTUS II 7.0. I use exactly the same *.sof file I use wit 7.1
http://www.teces.si/download/Hex_data_01.jpg
The "Hex User Data" part looks like it is missing its field. Highlight it and hit remove, either that or set a file to it and that should get you up and running.
Thx. Its working fine now!
