I wrote my first design in AHDL and it complied fine. When i did the functional simulation. I added various nodes in the simulation which contained both Input/Output pins and buried registers. My problem is when the simulation is complete during the waveform update process , my I/O pins are there but all the registers disappear:( . I don't know why...
Can anyone tell me why and the way to get around it.... Thanks SandoLink Copied
Here it is.
Open your _.vwf, then "Insert node or bus>Node finder>Filter>Registers" .... Good luck.- Mark as New
ye.. i did that and it puts register ( a D flip flop) in my waveform file. But the problem starts when i do "Start compilation and simulation". Once i do that and it returns success, then it ask s me if i want to update the vector file with latest vector file. i say yes as i have to see the result and once i do that node i added (i.e. a D flip) disappears. I have attached a snapshot of my problem. if anybody can figure it out... ?????
Are there any simulation results for that signal? If its getting compiled out (becuase its not used) then it'll also be removed in simulation and when you update it wont be there.
yes there are and that is not the only one register that disappears.. there are several more.. actually any register that i add, it disappears but that is not the case of I/O Pins.. :confused:
Can you post the code? I suspect that Quartus is removing the registers becuase they are not needed or can be optimized out, and thus the simulation is invalid.
Are you generating a functional netlist after compilation?
yes.. i did..
--- Quote Start --- yes there are and that is not the only one register that disappears.. there are several more.. actually any register that i add, it disappears but that is not the case of I/O Pins.. :confused: --- Quote End --- Once you add and remove registers in your top project. You must compile the project and change your _.vwf again. That's why you can't find the registers. Good luck.
Under node finder in vwf, if you filter to "Registers post fitting", you can see that what you are look for is not there. This is because the registers have been compiled out by quartus. Scanning over your code I can see whats wrong is on line 75 Serial_Out_D[].clrn = GND; clrn is active low, so the Serial_Out_D reg is getting removed. This needs to be tied to VCC. After changing this, I can now see all the registers in simulation. Regards- Subscribe to RSS Feed
