20725 Discussions
Call Procedure inside Function
Hi, i have a question: How can i call a Procedure inside of a Function?
The Quartus show me: VHDL error at Decod.vhd(150): cannot access 'maissig' from inside pure function 'soma'.
my code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Decod is port ( CLK : in std_logic; -- SINAL DE CLOCK Dados : in std_logic_vector (7 downto 0); Ch_A : in std_logic; Ch_B : in std_logic; Ch_C : in std_logic; out3 : out integer; out4 : out integer; Disp1 : out std_logic_vector(7 downto 0); Disp2 : out std_logic_vector(7 downto 0); Disp3 : out std_logic_vector(7 downto 0)); end Decod; architecture Funcao of Decod is type Chave is (Zero, Um, Dois, Tres, Quatro, Cinco, Seis, Sete); signal Estado : Chave := Zero; signal word : std_logic_vector (11 downto 0) := "000000000000"; signal D1 : integer range 0 to 15; signal D2 : integer range 0 to 15; signal D3 : integer range 0 to 15; signal MaisSig : std_logic_vector (7 downto 0) := "00000000"; signal MenosSig : std_logic_vector (7 downto 0) := "00000000"; signal H_Alto : integer; signal H_Baixo : integer; signal a : std_logic_vector(3 downto 0); signal b : std_logic_vector(3 downto 0); PROCEDURE Nibble ( Vetor : in std_logic_vector (7 downto 0); signal P_alta : out std_logic_vector (7 downto 0); signal P_baixa : out std_logic_vector (7 downto 0)) is BEGIN P_alta (3 downto 0) <= Vetor(7 downto 4); P_baixa (3 downto 0) <= Vetor(3 downto 0); END Nibble; FUNCTION Soma ( Vetor : std_logic_vector (7 downto 0); a : integer; b : integer) RETURN INTEGER IS variable Som : integer range 0 to 30 := 0; variable V_a : std_logic_vector (7 downto 0); variable V_b : std_logic_vector (7 downto 0); BEGIN Nibble (Vetor(7 downto 0), MaisSig(7 downto 0), MenosSig(7 downto 0)); V_a := MaisSig; V_b := MaisSig; a := Decimal(V_a(7 downto 0)); b := Decimal(V_b(7 downto 0)); Som := a + b; RETURN Som; END Soma; end funcao; Please, where the error?
pure functions can only access internal variables.
To access varaibles outside the function, you either need to pass them into the function (VIA the inputs) or declare the function as impure:
impure function soma(..) return integer is....
I wouldnt do this though as you're trying to read signals. I would pass them in as function inputs.
