hello
i do a clock to 24 hours in vhdl. i am using cyclone 2. I do vhdl files, test them with model sim, after that the comipations goes on with warnings, but it do not work on the fpga ? why ? i can not understand please helpLink Copied
Post some code and we can have a look.
From what you say, I can only guess that you have use a bad coding style, but without seeing the code I cant say any more.- Mark as New
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity counter_devidor is
port (
CLK, RST :in std_logic;
devided_clk : inout std_logic
-- Q :out std_logic_vector(24 downto 0)
end counter_devidor;
architecture beh of counter_devidor is
signal QL : std_logic_vector (24 downto 0);
begin
process(CLK, RST) begin
if (RST = '1') then
QL <= "1011111010111100001000000";
devided_clk <= '0';
elsif (CLK'event and CLK = '1') then
if (QL = "0000000000000000000000000") then
devided_clk <= not(devided_clk);
else
QL <= QL - 1;
end if;
end if;
end process;
--Q <= QL;
end beh;
library ieee;
entity counter60seconds is
port (
clk, reset: in std_logic;
seconds60 : inout std_logic
end counter60seconds;
architecture beh of counter60seconds is
signal cnt : std_logic_vector (5 downto 0);
--signal sec_sign : std_logic;
begin
process (clk, reset )
begin
if (reset = '1') then cnt <= "111100" ; seconds60 <= '0' ; else
if (clk'event and clk = '1') then
if (reset /= '1') then if (cnt = "000001") then seconds60 <= not(seconds60); cnt <= "011110"; else cnt <= cnt - 1 ; end if; end if ;
end if;
end if ;
end process;
end beh;
library ieee;
entity counter_10_min is
port (
devided_clk_10_sec : inout std_logic;
Q_10_min :out std_logic_vector(3 downto 0);
numbers_min10 :inout std_logic_vector(3 downto 0);
flagFirst : inout std_logic
end counter_10_min;
architecture beh of counter_10_min is
signal QL : std_logic_vector (3 downto 0);
--signal numbers_sec10_sign : std_logic_vector (3 downto 0);
begin
if (RST = '1') then
QL <= "1010";
flagFirst <= '0';
-- numbers_sec10 <= "0000";
devided_clk_10_sec <= '0';
if (QL = "0001") then
QL <= "0101";
devided_clk_10_sec <= not(devided_clk_10_sec);
flagFirst <= '1';
else
QL <= QL - 1;
end if;
end if;
end process;
--process(CLK, RST, devided_clk_10_sec) begin
-- if (RST = '1') then
-- numbers_sec10_sign <= "0000";
--elsif (devided_clk_10_sec'event and devided_clk_10_sec='1' ) then
--numbers_sec10 <= "0000";
--numbers_sec10_sign <= numbers_sec10_sign +1 ;
--end if ;
-- end if ;
-- end process;
Q_10_min <= QL;
--numbers_sec10 <= numbers_sec10_sign;
end beh;
use ieee.std_logic_1164.all ;
entity counterSixtyMin is
port (
clk_in_10_min, reset: in std_logic;
q_Sixty_min_7_segment : out std_logic_vector (3 downto 0) ;
--q_Sixty_min : out std_logic_vector (2 downto 0) ;
q_Sixty_min_Signal : out std_logic;
rst : in std_logic
end counterSixtyMin;
architecture arch of counterSixtyMin is
signal cnt : std_logic_vector (2 downto 0);
signal cnt_7_segnent : std_logic_vector (3 downto 0);
begin
process (clk_in_10_min, reset , rst )
begin
if (reset = '1' or rst = '1') then cnt <= "000" ; cnt_7_segnent <= "0000";
elsif (clk_in_10_min'event and clk_in_10_min = '0') then
if (cnt = "101") then cnt <= "000" ; cnt_7_segnent <= "0000"; else cnt <= cnt +1 ; cnt_7_segnent <= cnt_7_segnent+ 1; end if ;
end if ;
end process;
--q_Sixty_min <= cnt;
q_Sixty_min_Signal <= cnt(2);
q_Sixty_min_7_segment <= cnt_7_segnent ;
end arch;
library ieee;
entity counterTenHours is
port (
clk_1_hour , reset: in std_logic;
q_10_HOURS : out std_logic_vector (3 downto 0) ;
q_10_hoursSignal : out std_logic;
rst : in std_logic
end counterTenHours;
architecture arch of counterTenHours is
signal cnt : std_logic_vector (3 downto 0);
begin
process (clk_1_hour, reset , rst)
begin
if (reset = '1' or rst = '1') then cnt <= "0000" ;
elsif (clk_1_hour'event and clk_1_hour = '0') then
if (cnt = "1001") then cnt <= "0000" ; else cnt <= cnt +1 ; end if ;
end if ;
end process;
q_10_HOURS <= cnt;
q_10_hoursSignal <= cnt(3);
end arch;
library ieee;
entity counterTo20Hours is
port (
clk_10_hour , reset: in std_logic;
--q_2_HOURS : out std_logic_vector (1 downto 0) ;
q_2_HOURS_7_segment : out std_logic_vector (3 downto 0) ;
rst : in std_logic
end counterTo20Hours;
architecture arch of counterTo20Hours is
signal cnt : std_logic_vector (1 downto 0);
signal cnt_7 : std_logic_vector (3 downto 0);
begin
process (clk_10_hour, reset, rst )
begin
if (reset = '1' or rst = '1') then cnt <= "00" ; cnt_7 <= "0000";
elsif (clk_10_hour'event and clk_10_hour = '0') then
if (cnt = "11") then cnt <= "00" ; else cnt <= cnt +1 ; cnt_7 <= cnt_7 +1 ; end if ;
end if ;
end process;
--q_2_HOURS <= cnt;
q_2_HOURS_7_segment <= cnt_7 ;
end arch;
library ieee;
entity decoder7seg is
port (DIGIT : in std_logic_vector(3 downto 0);
SEG : out std_logic_vector(6 downto 0) );
end entity decoder7seg;
architecture decoder7seg_a of decoder7seg is
begin
--decode : process DIGIT is
SEG <= "1000000" when DIGIT="0000" else -- 0
"1111001" when DIGIT="0001" else -- 1
"0100100" when DIGIT="0010" else -- 2
"0110000" when DIGIT="0011" else -- 3library ieee;
"0011001" when DIGIT="0100" else -- 4
"0010010" when DIGIT="0101" else -- 5
"0000010" when DIGIT="0110" else -- 6
"1111000" when DIGIT="0111" else -- 7
"0000000" when DIGIT="1000" else -- 8
"0010000" when DIGIT="1001" else -- 9
"0001000" when DIGIT="1010" else -- A
"0000011" when DIGIT="1011" else -- b
"1000110" when DIGIT="1100" else -- C
"0100001" when DIGIT="1101" else -- d
"0000110" when DIGIT="1110" else -- E
"0001110" when DIGIT="1111" else -- F
"0000000";
end architecture decoder7seg_a;
library ieee;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.numeric_std.ALL;
entity clockTop is
port (
clk50Mhz : in std_logic;
resetTop : in std_logic;
tenMinutesOut : out std_logic_vector (6 downto 0);
sixtyMinOut : out std_logic_vector (6 downto 0);
TenHoursOut : out std_logic_vector (6 downto 0);
TwoHoursOut : out std_logic_vector (6 downto 0)
end clockTop;
architecture struct of clockTop is
component counter60seconds
port (
end component;
component secondGenerator
port (
end component ;
component counterToTen is
port (
q_MIN : out std_logic_vector (3 downto 0) ;
q_10_minSignal : out std_logic;
rst : in std_logic
end component;
component counterSixtyMin is
port (
rst : in std_logic
end component;
component counterTenHours is
port (
rst : in std_logic
end component;
component counterTo20Hours is
port (
rst : in std_logic
end component;
component segment7
end component;
signal reset_sign : std_logic;
signal OneSecWire : std_logic ;
signal q_line : std_logic_vector(24 downto 0);
signal OneMinWire : std_logic;
signal q_10_minutes_signal : std_logic_vector(3 downto 0);
signal q_10_minSignal_IntSign : std_logic;
signal q_Sixty_min_Signal_IntSign : std_logic;
signal q_10_HOURS_IntSign_Vector : std_logic_vector (3 downto 0);
signal q_10_hoursSignal_IntSign : std_logic;
signal q_2_HOURS_7_segment_IntSign : std_logic_vector (3 downto 0);
signal q_Sixty_min_7_segment_IntSign : std_logic_vector (3 downto 0);
signal rst_signal : std_logic;
for ALL: segment7 use entity work.decoder7seg(decoder7seg_a);
for ALL : counterTo20Hours use entity work.counterTo20Hours;
for ALL : counterTenHours use entity work.counterTenHours;
for ALL : counterSixtyMin use entity work.counterSixtyMin;
for ALL: counterToTen use entity work.counterToTen;
for ALL: secondGenerator use entity work.counter_devidor;
for ALL : counter60seconds use entity work.counter60seconds;
begin
secondGeneratorInst : secondGenerator port map ( clk50Mhz, reset_sign ,OneSecWire ) ;
counter60secondsInst : counter60seconds port map (OneSecWire, reset_sign, OneMinWire ) ;
counterToTenInst : counterToTen port map (
OneMinWire, reset_sign,
q_10_minutes_signal,
q_10_minSignal_IntSign,
rst_signal
counterSixtyMinInst : counterSixtyMin
port map(
q_10_minSignal_IntSign, reset_sign,
q_Sixty_min_7_segment_IntSign ,
--q_Sixty_min : out std_logic_vector (2 downto 0) ,
q_Sixty_min_Signal_IntSign,
rst_signal
counterTenHoursInst :counterTenHours
port map (
q_Sixty_min_Signal_IntSign , reset_sign,
q_10_HOURS_IntSign_Vector,
q_10_hoursSignal_IntSign,
rst_signal
counterTo20HoursInst: counterTo20Hours
port map (
q_10_hoursSignal_IntSign , reset_sign,
q_2_HOURS_7_segment_IntSign,
rst_signal
segment7_10Min : segment7 port map (q_10_minutes_signal, tenMinutesOut);
segment7_60Min : segment7 port map (q_Sixty_min_7_segment_IntSign, sixtyMinOut);
segment7_10hours : segment7 port map (q_10_HOURS_IntSign_Vector, TenHoursOut);
segment7_2hours : segment7 port map (q_2_HOURS_7_segment_IntSign, TwoHoursOut);
process (clk50Mhz, resetTop, q_2_HOURS_7_segment_IntSign , q_10_HOURS_IntSign_Vector , q_Sixty_min_7_segment_IntSign , q_10_minutes_signal )
begin
if (clk50Mhz'event and clk50Mhz = '1') then
if (q_2_HOURS_7_segment_IntSign = "0010" and q_10_HOURS_IntSign_Vector = "0011" and q_Sixty_min_7_segment_IntSign = "0101" and q_10_minutes_signal = "1001" ) then
rst_signal <= '1';
end if;
end if ;
end process;
reset_sign <= resetTop;
end;
that is ... in simulation is ok ... but ot nthe fpga do not works ...
Here is your big problem - you are generating a load of clocks in logic. Dont do that. Generate enable signals instead and run ALL registers from the system clock "clk".
also, your derived clocks look at falling edge, and other clocks look for rising edge. Convention is to have all clocks work on the rising edge. For a clock deisgn, you seem to have made it very complicated.- Mark as New
so you tell me that i have a single clock ? how can i reach this ?
when 1 min goes the eneable of the counter to 10 min should be on for 1 pulse of the shared single clock ? i am not sure that is your idea ... the fpga module takes 50 mhz clock input - is this the shared clock that i should use or devided clock with T with 1 sec is it good idea to use frequency devidor to reach 1 second T or i shoud use enable ?- Mark as New
Use the 50Mhz clock. Never use derived clocks (unless you use a PLL)
The template you should use for enabled registers is this:
process(clk_50MHz, reset)
begin
if reset = '1' then
--reset D
elsif rising_edge(clk_50MHz) then
if enable = '1' then --this can be things like "enable minute" or something
q <= d;
end if;
end if;
end process;
why i can not use derived clock ?
Using normal FPGA logic to create clock signals (ie,clock dividers and clock gates) creates timming problems because those clocks signals often end up with large skews.
what should i understand for "large skews"
The derrived clock wont arrive at each register at the same time.
i do this design
counter to 2 <- coutner to 10 <- counter to 6 <- counter to 10 i want to make counter to 24 hours the counter to 24 works fine the counter to 60 works fine whne i connect the two counters it start to work not properly whne it reach 9 it jumps to 12 ... when it goest to 19 it jumps in 22 when reach 29 i jump to 32 can it be from derived clockes or it is somethin else how can i solve this problem ? please help- Mark as New
--- Quote Start --- Use the 50Mhz clock. Never use derived clocks (unless you use a PLL) The template you should use for enabled registers is this:
begin
if reset = '1' then
--reset D
q <= d;
end if;
end if;
end process;
--- Quote End --- but how can i do addition with enables ?
begin
if reset = '1' then
--reset D
q <= q + 1;
end if;
end if;
end process;
