Trying to follow the hardware tutorial example to re-create the 'standard' configuration for a Cyclone-II board. I get this:
Altera SOPC Builder Version 7.00 Build 33 Copyright (c) 1999-2006 Altera Corporation. All rights reserved. # 2007.09.18 15:28:30 (*) mk_custom_sdk starting # 2007.09.18 15:28:30 (*) Reading project G:/EngData/EP2189_niostest/standard/std_2C35.ptf. # 2007.09.18 15:28:31 (*) Finding all CPUs # 2007.09.18 15:28:31 (*) Finding all available components # 2007.09.18 15:28:31 (*) Reading G:/EngData/EP2189_niostest/standard/.sopc_builder/install.ptf # 2007.09.18 15:28:31 (*) Found 63 components # 2007.09.18 15:28:32 (*) Finding all peripherals # 2007.09.18 15:28:33 (*) Finding software components # 2007.09.18 15:28:34 (*) (Legacy SDK Generation Skipped) # 2007.09.18 15:28:34 (*) (All TCL Script Generation Skipped) # 2007.09.18 15:28:34 (*) (No Libraries Built) # 2007.09.18 15:28:34 (*) (Contents Generation Skipped) # 2007.09.18 15:28:34 (*) mk_custom_sdk finishing # 2007.09.18 15:28:34 (*) Starting generation for system: std_2C35. ................. # 2007.09.18 15:28:36 (*) Running Generator Program for cpu and two hours later - NOTHING! Any clues please? JohnLink Copied
Well, 18 months have passed and still no joy. I have two laptops here that both run 7.0, 7.1, 7.2sp2. But I installed 8.1 otnight and still the same problem persists:
Altera SOPC Builder Version 8.10 Build 163 Copyright (c) 1999-2008 Altera Corporation. All rights reserved. # 2009.03.05 01:17:39 (*) mk_custom_sdk starting # 2009.03.05 01:17:39 (*) Reading project C:/altera/81/nios2eds/examples/vhdl/niosII_cycloneII_2c35/standard/NiosII_cycloneII_2c35_standard_sopc.ptf. # 2009.03.05 01:17:40 (*) Finding all CPUs # 2009.03.05 01:17:40 (*) Finding all available components # 2009.03.05 01:17:40 (*) Reading C:/altera/81/nios2eds/examples/vhdl/niosII_cycloneII_2c35/standard/.sopc_builder/install.ptf # 2009.03.05 01:17:40 (*) Found 67 components # 2009.03.05 01:17:42 (*) Finding all peripherals # 2009.03.05 01:17:42 (*) Finding software components # 2009.03.05 01:17:43 (*) (Legacy SDK Generation Skipped) # 2009.03.05 01:17:43 (*) (All TCL Script Generation Skipped) # 2009.03.05 01:17:43 (*) (No Libraries Built) # 2009.03.05 01:17:43 (*) (Contents Generation Skipped) # 2009.03.05 01:17:43 (*) mk_custom_sdk finishing # 2009.03.05 01:17:43 (*) Starting generation for system: NiosII_cycloneII_2c35_standard_sopc. .................. # 2009.03.05 01:17:46 (*) Running Generator Program for pll Error: System generation was cancelled. Am I the only person having this problem? John- Mark as New
do you install the nios ii embedded design suite ?
Yes, I downloaded the complete 8.1 subscription edition from the Altera website. I have a full licence for it which seems to be working just fine. Well, at least on Quartus. Using the prebuilt system I can write software and download the code as well as the pof file to the board. THe only problem I seem to have is that the PLL generator goes into la-la land and so the remainder of the process doesn't happen either.
John- Subscribe to RSS Feed
