Hi..
I am currently working on a project based on image compression. Using quartus II i could see simulation waveforms only till 1000ns. As quartus has no mode of writing test benches... can anyone suggest me a way to write my output to a text file or something in verilog. Really in need of help.. Thanks Sri HarshaLink Copied
When your .vwf file is open, do a File -> Save As, or File -> Export, and there should be different text formats available. It is recommended to use the Altera Modelsim version with Quartus, since that allows testbenches(and a whole host of other capabilities the Altera simulator does not).
Topic Options
