12606 Discussions
Monitoring all loaded processes
I wondered if anybody could help me with this: I want to monitor all the processes that are loaded in µClinux (CPU usage, memory usage,...).
Warm Regards
Look in the /proc file system.
--- Quote Start ---
originally posted by hippo@Mar 22 2006, 03:30 AM
look in the /proc file system.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13657)
--- quote end ---
--- Quote End ---
Ok hippo,
thanks
Warm Regards
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13655)
--- Quote End ---
[/b]
--- Quote End ---
To do so I executed the ps command, it gives all the stuff I need, unfortunately there is no top command so I got to write a script to execute the ps command every 3s and write results to a file.
If anybody could help in that, that&#39;s gonna be cool.
Warm Regards.
--- Quote Start ---
originally posted by mfm@Mar 24 2006, 02:42 AM
...unfortunately there is no top command so i got to write a script to execute the ps command every 3s and write results to a file.
if anybody could help in that, that&#39;s gonna be cool.
--- Quote End ---
Hi MFM,
I haven&#39;t tried it yet, but it looks like top command may already have been been ported http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
* Follow step 13 here...
http://forum.niosforum.com/forum/index.php?showtopic=3174# (http://forum.niosforum.com/forum/index.php?showtopic=3174#
* Select Miscellaneous Applications --> Propcs tools --> top
Oops. I tried building the top and setserial apps from dist-test, however no binaries were generated.
Any ideas?
--- Quote Start ---
unfortunately there is no top command so I got to write a script to execute the ps command every 3s and write results to a file.[/b]
--- Quote End ---
well, I wrote that script and it works fine with one exception:
I want to launch the ps command every 3s and save results in mfm.txt till the q key is pressed.
I&#39;m still testing it in Redhat before implementing it in µClinux.
The only problem is how to get the q key stopping the execution of the script
# !/bin/sh
touch mfm.txt
until [ "$*" = "q" ];
      do
            sleep 3
            date >> mfm.txt
            ps >> mfm.txt
            echo " " >> mfm.txt;
done
Can anybody help me with that ?
Warm Regards
Why are you doing this when you can just get &#39;top&#39; from busybox? Moreso, doesn&#39;t the processor need some sort of time reference to actual calculate loading on the CPU? IE: a RTC
--- Quote Start ---
# !/bin/sh
touch mfm.txt
      do
            sleep 3
            date >> mfm.txt
            ps >> mfm.txt
done
# ##################################/b
--- Quote End ---
I&#39;ve tried to execute that script under µClinux after changing the sleep 3 command, which isn&#39;t implemented in µClinux, by the following:# ###############
for ((a=1;a<300;a++))
     do echo
done# ###############
But unfortunately it won&#39;t work http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
I&#39;m getting some "syntax error".
Can anybody help me with that.
Warm Regards
--- Quote Start ---
originally posted by jdhar@Mar 24 2006, 06:02 PM
why are you doing this when you can just get &#39;top&#39; from busybox?
--- Quote End ---
that&#39;s cause I spent a lot of time trying to compile it but all I got is a lot of errors
maybe you can help.
This is the console output (I&#39;m under Windows)
--- Quote Start ---
make -k all
  no emulation specific options.
nios2-elf-gcc -nostdinc -D__linux__ -O2 -I"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall -c -o top.o top.c
In file included from top.c:37:
page.h:27:20: config.h: No such file or directory
In file included from busybox.h:27,
              from top.c:38:
config.h:4:28: linux/autoconf.h: No such file or directory
In file included from busybox.h:54,
              from top.c:38:
libbb.h:49:18: pwd_.h: No such file or directory
libbb.h:50:18: grp_.h: No such file or directory
              from top.c:38:
libbb.h:426: warning: "struct passwd" declared inside parameter list
libbb.h:426: warning: its scope is only this definition or declaration, which is probably not what you want
libbb.h:427: warning: "struct passwd" declared inside parameter list
libbb.h:435: warning: "struct passwd" declared inside parameter list
libbb.h:436: warning: "struct passwd" declared inside parameter list
libbb.h:438: warning: "struct passwd" declared inside parameter list
libbb.h:439: warning: "struct passwd" declared inside parameter list
top.c:57: warning: &#39;pid_sort&#39; defined but not used
make: *** [top.o] Error 1
make: Target `all&#39; not remade because of errors.[/b]
--- Quote End ---
--- Quote Start ---
--- Quote End ---
I succeded in building that one but when I launch it, µClinux reboot.
I tested it again and again and it&#39;s always the same!!!!!!!
Any idea?
Warm Regards
If you are looking for something GUI based like Windows task manager, Then have a look at LTaMe (Linux Task Manager) in source forge. This was made by me and 3 of my friends. Works but got some small bugs. It is made of QT. If u want to monitor tasks running on target you will have to write some socket programs and run LTaMe on ur linux box. It currentlygives details about the linux box on which u run LTaMe. Have a look.
--- Quote Start ---
Is any one interested in doing that??????????????????[/b]
--- Quote End ---
--- Quote Start ---
originally posted by mfm+mar 25 2006, 01:31 am--><div class='quotetop'>quote (mfm @ mar 25 2006, 01:31 am)</div>
--- quote start ---
<!--quotebegin-jdhar@Mar 24 2006, 06:02 PM
--- Quote End ---
Any idea?
Warm Regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13771)</div>
[/b]
--- Quote End ---
I checked the &#39;top&#39; of busybox with buildroot tools. It runs without problem.
TO_BE_DONE
