AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
Erreur SSD 545s 10/106
Papyboulou
Bonjour,
Depuis quelques jours maintenant en utilisant SSD optimizer j'ai une "erreur 10/106"
SSD toolbox est à jour, le firmware aussi.
Comment régler le problème, merci.
For a few days now using SSD optimizer I have a "10/106 error"
SSD toolbox is up to date, the firmware too.
How to fix the problem, thank you.
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (look at the instructions under the reply window).
Doc
Papyboulou
Fichier joint, merci beaucoup.
Attachment, thank you very much.
