I am trying to use intel-npu-acceleration library to enable local LLM inference task. However, it seems that the library does not support GGUF file parsing?
Hi Martin_HZK,
As the intel/intel-npu-acceleration-library: Intel® NPU Acceleration Library is not supported here, could you please to check your quesiton to Intel® Distribution of OpenVINO™ Toolkit - Intel Community
or Issues · openvinotoolkit/openvino
FYI, I also noticed some developer also try to use Ollama openvino : like zhaohb/ollama_ov: Add genai backend for ollama to run generative AI models using OpenVINO Runtime. you may try them.
Topic Options
