AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
libmkl_sycl.so.3: Cannot open shared object file
Vaibhav_S_Intel
I have installed the latest 2024.x intel base tool kit for one API from intel website on my ADL ubuntu machine with ARC GPU.
I'm trying to run pytorch with intel_extension_for_pytorch
Why i execute the python code to check torch version and pytorch extension, it throws an error -->
ImportError                               Traceback (most recent call last)
Cell In[1], line 5
      1 # Import PyTorch dependencies
      4 import torch
----> 5 import intel_extension_for_pytorch as ipex
      7 print(f'PyTorch Version: {torch.__version__}')
      8 print(f'Intel PyTorch Extension Version: {ipex.__version__}')
File ~/mambaforge/envs/pytorch-arc/lib/python3.11/site-packages/intel_extension_for_pytorch/__init__.py:93
     89                 raise err
     91     kernel32.SetErrorMode(prev_error_mode)
---> 93 from .utils._proxy_module import *
     94 from . import cpu
     95 from . import xpu
File ~/mambaforge/envs/pytorch-arc/lib/python3.11/site-packages/intel_extension_for_pytorch/utils/_proxy_module.py:2
      1 import torch
----> 2 import intel_extension_for_pytorch._C
      5 # utils function to define base object proxy
      6 def _proxy_module(name: str) -> type:
ImportError: libmkl_sycl.so.3: cannot open shared object file: No such file or directory
I have imported all the lib and compiler paths in .bashrc. Need your help to resolve this error.
When checked opt/intel/oneapi path for available MKL libs, it only has  libmkl_sycl.so and no libmkl_sycl.so.3 . creating a soft link for .3 gives me a ELF error.
Vipin_S_Intel
Hi Vaibhav, we would like to inform you that we are routing your query to the dedicated team for further assistance.
Ying_H_Intel
Thank you a lot for raising the problem! ​ the  libmkl_sycl.so.3 is from earier oneAPI 2023.x version.
Good thing, we release a new version for oneAPI and Intel optimized pytorch. you can install by
sudo apt install -y intel-oneapi-dpcpp-cpp-2024.1=2024.1.0-963 intel-oneapi-mkl-devel=2024.1.0-691 intel-oneapi-ccl-devel=2021.12.0-309 --> you may already install the version, then please ignore the step
python -m pip install torch==2.1.0.post0 torchvision==0.16.0.post0 torchaudio==2.1.0.post0 intel-extension-for-pytorch==2.1.20+xpu --extra-index-url https://pytorch-extension.intel.com/release-whl/stable/xpu/us/
from more detail, please see Welcome to Intel® Extension for PyTorch* Documentation!
YIng
