AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
164 Discussions
oneAPI AI Anlytics Toolkit Install via Conda Package Manager on Clean Ubuntu 20.04 LTS
Nathan_Peper
I have a NUC with a fresh Ubuntu 20.04 LTS install that I’m trying to install the Intel oneAPI AI Analytics Toolkit on.  I can get everything to work through the GUI based installer and if I use APT, but if I only install Miniconda and then use the Conda Package Manager I run into some issues. I’m not sure if there is an undocumented step(s) or prereq(s) that I’m missing.  There’s a comment about setting up the environment variables to access the tools, but it doesn’t look like I can use the “source /opt/intel/oneapi/setvars.sh” like in the other install methods when only using conda and no previous oneAPI installs through the other methods.
I’m following the instructions as outlined in the below link on our site, but get the below results in the terminal. I run into this error when I try to import tensorflow in python.
Thanks for the help,
Nate
Snapshot of the error:
(oneapi-tf) npeper@TGL-i7-NUC-1:~$ python -c "import tensorflow as tf"
Traceback (most recent call last):
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/numpy/core/__init__.py", line 22, in <module>
    from . import multiarray
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/numpy/core/multiarray.py", line 12, in <module>
    from . import overrides
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/numpy/core/overrides.py", line 7, in <module>
    from numpy.core._multiarray_umath import (
ImportError: libmkl_rt.so.1: cannot open shared object file: No such file or directory
Install instructions on our website:
https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/install-using-package-managers/conda/install-intel-ai-analytics-toolkit-via-conda.html
Full terminal steps and output:
npeper@TGL-i7-NUC-1:~$ source /home/npeper/miniconda3/bin/activate
(base) npeper@TGL-i7-NUC-1:~$ conda create -n oneapi-tf -c intel intel-aikit-tensorflow
Collecting package metadata (current_repodata.json): done
Solving environment: done
## Package Plan ##
  environment location: /home/npeper/miniconda3/envs/oneapi-tf
  added / updated specs:
    - intel-aikit-tensorflow
The following NEW packages will be INSTALLED:
  absl-py            intel/linux-64::absl-py-0.12.0-py37h06a4308_0
  aiohttp            intel/linux-64::aiohttp-3.7.4-py37h27cfd23_1
  asn1crypto         intel/linux-64::asn1crypto-1.4.0-py37hcd5400e_2
  astor              intel/linux-64::astor-0.8.1-py37h06a4308_0
  astunparse         intel/noarch::astunparse-1.6.3-py_0
  async-timeout      intel/linux-64::async-timeout-3.0.1-py37h06a4308_0
  attrs              intel/noarch::attrs-21.2.0-pyhd3eb1b0_0
  blinker            intel/linux-64::blinker-1.4-py37h06a4308_0
  bzip2              intel/linux-64::bzip2-1.0.8-hb9a14ef_9
  c-ares             intel/linux-64::c-ares-1.17.1-h14c3975_3
  ca-certificates    intel/linux-64::ca-certificates-2021.10.26-h06a4308_2
  cached-property    intel/noarch::cached-property-1.5.2-py_0
  cachetools         intel/noarch::cachetools-4.2.2-pyhd3eb1b0_0
  certifi            intel/linux-64::certifi-2021.10.8-py37h06a4308_0
  cffi               intel/linux-64::cffi-1.14.6-py37h400218f_0
  chardet            intel/linux-64::chardet-3.0.4-py37h82fad40_4
  click              intel/noarch::click-8.0.3-pyhd3eb1b0_0
  cloudpickle        intel/noarch::cloudpickle-1.6.0-py_0
  contextlib2        intel/noarch::contextlib2-0.5.5-py_2
  coverage           intel/linux-64::coverage-5.5-py37h27cfd23_2
  cryptography       intel/linux-64::cryptography-3.3.2-py37h3d3d174_1
  cython             intel/linux-64::cython-0.29.24-py37hbf8da92_2
  daal4py            intel/linux-64::daal4py-2021.5.1-py37_intel_803
  dal                intel/linux-64::dal-2021.5.1-intel_803
  dataclasses        intel/noarch::dataclasses-0.8-pyh6d0b6a4_7
  dpcpp-cpp-rt       intel/linux-64::dpcpp-cpp-rt-2022.0.1-intel_3633
  dpcpp_cpp_rt       intel/linux-64::dpcpp_cpp_rt-2022.0.1-intel_3633
  flatbuffers        intel/linux-64::flatbuffers-2.0.0-h2531618_0
  fortran_rt         intel/linux-64::fortran_rt-2022.0.1-intel_3633
  future             intel/linux-64::future-0.18.2-py37_1
  gast               intel/noarch::gast-0.4.0-py_0
  google-auth        intel/noarch::google-auth-1.33.0-pyhd3eb1b0_0
  google-auth-oauth~ intel/noarch::google-auth-oauthlib-0.4.1-py_2
  google-pasta       intel/noarch::google-pasta-0.2.0-py_0
  grpcio             intel/linux-64::grpcio-1.36.1-py37h2157cd5_1
  h5py               intel/linux-64::h5py-3.2.1-py37h6c542dc_0
  hdf5               intel/linux-64::hdf5-1.10.6-hb1b8bf9_0
  hyperopt           intel/noarch::hyperopt-0.2.5-pyh9f0ad1d_0
  icc_rt             intel/linux-64::icc_rt-2022.0.1-intel_3633
  idna               intel/linux-64::idna-3.1-py37hf52dec2_0
  impi-devel         intel/linux-64::impi-devel-2021.5.0-intel_497
  impi_rt            intel/linux-64::impi_rt-2021.5.0-intel_pycpuinfo_496
  importlib-metadata intel/linux-64::importlib-metadata-3.10.0-py37h06a4308_0
  intel-aikit-tenso~ intel/linux-64::intel-aikit-tensorflow-2021.3.0-0
  intel-cmplr-lib-rt intel/linux-64::intel-cmplr-lib-rt-2022.0.1-intel_3633
  intel-cmplr-lic-rt intel/linux-64::intel-cmplr-lic-rt-2022.0.1-intel_3633
  intel-fortran-rt   intel/linux-64::intel-fortran-rt-2022.0.1-intel_3633
  intel-opencl-rt    intel/linux-64::intel-opencl-rt-2022.0.1-intel_3633
  intel-openmp       intel/linux-64::intel-openmp-2022.0.1-intel_3633
  intelpython        intel/linux-64::intelpython-2022.0.0-0
  joblib             intel/linux-64::joblib-1.0.1-py37h3f38642_0
  keras-preprocessi~ intel/noarch::keras-preprocessing-1.1.2-pyhd3eb1b0_0
  libffi             intel/linux-64::libffi-3.3-14
  libgcc-ng          intel/linux-64::libgcc-ng-9.3.0-hdf63c60_101
  libgfortran-ng     intel/linux-64::libgfortran-ng-7.3.0-hdf63c60_0
  libprotobuf        intel/linux-64::libprotobuf-3.14.0-he78db7b_1
  libstdcxx-ng       intel/linux-64::libstdcxx-ng-9.3.0-hdf63c60_101
  lpot               intel/noarch::lpot-1.0-py_0
  markdown           intel/linux-64::markdown-3.3.4-py37h06a4308_0
  mkl                intel/linux-64::mkl-2022.0.1-intel_117
  mkl-service        intel/linux-64::mkl-service-2.4.0-py37h4119f30_11
  mkl_fft            intel/linux-64::mkl_fft-1.2.0-py37hb9c2cde_4
  mkl_random         intel/linux-64::mkl_random-1.2.0-py37h90a4e38_4
  mkl_umath          intel/linux-64::mkl_umath-0.1.0-py37hb46b53c_0
  multidict          intel/linux-64::multidict-5.1.0-py37h27cfd23_2
  networkx           intel/noarch::networkx-2.6.2-pyhd3eb1b0_2
  numpy              intel/linux-64::numpy-1.19.2-py37h02626c5_0
  numpy-base         intel/linux-64::numpy-base-1.19.2-py37h591eb60_0
  oauthlib           intel/noarch::oauthlib-3.1.1-pyhd3eb1b0_0
  openssl            intel/linux-64::openssl-1.1.1l-h7f8727e_0
  opt_einsum         intel/noarch::opt_einsum-3.3.0-pyhd3eb1b0_1
  pandas             intel/linux-64::pandas-1.2.0-py37hef31ef9_2
  pip                intel/linux-64::pip-21.2.2-py37h06a4308_0
  protobuf           intel/linux-64::protobuf-3.14.0-py37h2531618_1
  py-cpuinfo         intel/noarch::py-cpuinfo-8.0.0-pyhd3eb1b0_0
  pyasn1             intel/noarch::pyasn1-0.4.8-py_0
  pyasn1-modules     intel/noarch::pyasn1-modules-0.2.8-py_0
  pycparser          intel/noarch::pycparser-2.21-pyhd3eb1b0_0
  pyjwt              intel/noarch::pyjwt-2.1.0-pyhd8ed1ab_0
  pymongo            intel/linux-64::pymongo-3.11.4-py37h2531618_0
  pyopenssl          intel/noarch::pyopenssl-21.0.0-pyhd3eb1b0_1
  pysocks            intel/linux-64::pysocks-1.7.1-py37_1
  python             intel/linux-64::python-3.7.11-h6ca7d21_6
  python-dateutil    intel/linux-64::python-dateutil-2.8.2-py37_1
  pytz               intel/noarch::pytz-2021.3-pyhd3eb1b0_0
  pyyaml             intel/linux-64::pyyaml-6.0-py37h7f8727e_1
  requests           intel/linux-64::requests-2.25.1-py37h6282448_1
  requests-oauthlib  intel/noarch::requests-oauthlib-1.3.0-py_0
  rsa                intel/noarch::rsa-4.7.2-pyhd3eb1b0_1
  schema             intel/noarch::schema-0.7.4-pyh44b312d_0
  scikit-learn       intel/linux-64::scikit-learn-0.24.2-py37h8411759_4
  scikit-learn-inte~ intel/linux-64::scikit-learn-intelex-2021.5.1-py37_intel_803
  scipy              intel/linux-64::scipy-1.5.2-py37h83b3cbf_0
  setuptools         intel/linux-64::setuptools-58.0.4-py37h06a4308_0
  six                intel/linux-64::six-1.16.0-py37_0
  sqlite             intel/linux-64::sqlite-3.36.0-hb9a14ef_3
  tbb                intel/linux-64::tbb-2021.5.0-intel_707
  tbb4py             intel/linux-64::tbb4py-2021.5.0-py37_intel_707
  tensorboard        intel/noarch::tensorboard-2.5.0-py_0
  tensorboard-plugi~ intel/noarch::tensorboard-plugin-wit-1.6.0-py_0
  tensorflow         intel/linux-64::tensorflow-2.5.0-py37_1
  tensorflow-estima~ intel/noarch::tensorflow-estimator-2.5.0-pyh7b7c402_0
  termcolor          intel/linux-64::termcolor-1.1.0-py37h06a4308_1
  threadpoolctl      intel/noarch::threadpoolctl-2.2.0-pyh0d69192_0
  tk                 intel/linux-64::tk-8.6.10-h8e2d9d6_3
  tqdm               intel/noarch::tqdm-4.62.3-pyhd3eb1b0_1
  typing-extensions  intel/noarch::typing-extensions-3.7.4.3-hd3eb1b0_0
  typing_extensions  intel/noarch::typing_extensions-3.7.4.3-pyh06a4308_0
  urllib3            intel/linux-64::urllib3-1.26.6-py37h6fed32d_1
  werkzeug           intel/noarch::werkzeug-2.0.2-pyhd3eb1b0_0
  wheel              intel/noarch::wheel-0.37.0-pyhd3eb1b0_1
  wrapt              intel/linux-64::wrapt-1.12.1-py37h7b6447c_1
  xz                 intel/linux-64::xz-5.2.5-h74280d8_2
  yaml               intel/linux-64::yaml-0.2.5-h7b6447c_0
  yarl               intel/linux-64::yarl-1.6.3-py37h27cfd23_0
  zipp               intel/noarch::zipp-3.6.0-pyhd3eb1b0_0
  zlib               intel/linux-64::zlib-1.2.11.1-h1e99aa7_5
Proceed ([y]/n)? y
Preparing transaction: done
Verifying transaction: done
Executing transaction: /
    Installed package of scikit-learn can be accelerated using scikit-learn-intelex.
    More details are available here: https://intel.github.io/scikit-learn-intelex
    For example:
        $ conda install scikit-learn-intelex
        $ python -m sklearnex my_application.py
done
# To activate this environment, use
#     $ conda activate oneapi-tf
# To deactivate an active environment, use
#     $ conda deactivate
(base) npeper@TGL-i7-NUC-1:~$ conda activate oneapi-tf
During handling of the above exception, another exception occurred:
  File "<string>", line 1, in <module>
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/tensorflow/__init__.py", line 41, in <module>
    from tensorflow.python.tools import module_util as _module_util
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/tensorflow/python/__init__.py", line 40, in <module>
    from tensorflow.python.eager import context
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/tensorflow/python/eager/context.py", line 29, in <module>
    import numpy as np
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/numpy/__init__.py", line 156, in <module>
    from . import core
  File "/home/npeper/miniconda3/envs/oneapi-tf/lib/python3.7/site-packages/numpy/core/__init__.py", line 48, in <module>
    raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
    https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
  * The Python version is: Python3.7 from "/home/npeper/miniconda3/envs/oneapi-tf/bin/python"
  * The NumPy version is: "1.19.2"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libmkl_rt.so.1: cannot open shared object file: No such file or directory
(oneapi-tf) npeper@TGL-i7-NUC-1:~$ cd /opt
(oneapi-tf) npeper@TGL-i7-NUC-1:/opt$ ls
google
Labels (3)
VaradJ_Intel
Thank you for posting in Intel communities.
We could reproduce your issue and we have a workaround for that. Try locating the libmkl_rt.so with the below command:
locate libmkl_rt.so
If locate command is not found, try installing with the following command:
sudo apt install mlocate
Try renaming all the files to libmkl_rt.so.1 with the below command:
mv <path>/libmkl_rt.so <path>/libmkl_rt.so.1
You would be getting an error that flatbuffers module is not found. You could resolve it by simply installing that package with the below command:
conda install -c conda-forge python-flatbuffers
Try importing tensorflow again & let us know if the issue still persists.
Thank You.
Nathan_Peper
Thank you so much for the help on this, it looks like that method works for the tensorflow import. While continuing to troubleshoot, I also found this as a fix to the issue:
https://stackoverflow.com/questions/58868528/importing-the-numpy-c-extensions-failed
  1. pip uninstall -y numpy
  2. pip uninstall -y setuptools
  3. pip install setuptools
  4. pip install numpy
  5. conda install -c conda-forge python-flatbuffers
Is one fix more robust or proper than the other here when looking to have all of the oneAPI features enabled?
Thank you!
VaradJ_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. Both the workarounds solves the issue but the workaround suggested by you looks more robust or proper. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thank You.
