Analyzers
5341 Discussions
Advisor Roofline assertion error
PedroGS
When I trying to generate the roofline model using Advisor via Devcloud, I am presenting the following error:
Assertion failed: m_gpuBandIdx.exist()
file: vcs/tpssplug2/src/tripcounts/tripcounts_plugin_bridge.cpp:1249
Collecting modules information...
Collecting system information...
Aborted
Command used: advisor --collect=roofline --profile-gpu –-project-dir=./ -- ./stencil_code input.dat
RaeesaM_Intel
Hi ,
Thank you for posting in Intel Forum .
Could you please share :
  1. The application and steps to reproduce the issue
  2. Version of Intel Advisor
Also we could observe that you are using a .dat file in the command. Can you please change that .dat file to an executable file of your application and do the analysis.
Let us know the updates .
Raeesa
PedroGS
The application is the stencil computation, having as input a file (input.dat) with information to perform the calculation.
Steps:
  1. compilation of code
  2. command usage: advisor --collect=roofline --profile-gpu --project-dir =. / -- ./stencil_code input.dat
PedroGS
Advisor version: Intel(R) Advisor 2021.1 (build 607872) Command Line Tool
RaeesaM_Intel
Could you please try roofline analysis with sample application in the folder <advisor-installation-directory>/2021.1.1/samples/en/C++/
Verify whether other types of analysis like survey analysis in advisor is running successfully using your stencil computation application.
Also, Please share the language of your application and the devcloud node you are using. It would be better if you could share the command you used to enter into devcloud node.
Raeesa
PedroGS
With the example C++ mmult_Advisor works fine.
When run only survey or tripcounts works but when try run both or only roofline get the error.
The application is in DPC++ .
YuliaE__Intel
What graphics card do you have?
Could you please share the profile collected by Advisor?
RaeesaM_Intel
We tried roofline analysis on dpc++ matrix multiplication sample and also on another sample available with advisor without any error.
Could you please share the devcloud node you are using. It would be better if you could share the command you used to enter into devcloud node.
Also , check whether any result folder named like e0000 is created in the directory where you run the command.
Raeesa
PedroGS
Command to access the node: qsub -I -l nodes=s001-n229:gpu:ppn=2 -d .
The e000 folder is created.
Sorry
RaeesaM_Intel
Hi ,
We tried running roofline analysis with –profile-gpu on sample dpc++ matrix application in the same node that you provided and it ran successfully. We might need a reproducer code for further debugging as the issue is not with the gpu node or the advisor. Could you please share the stencil application or result folder with us ?
Raeesa
RaeesaM_Intel
Is your issue resolved ? Please let us know the updates so than we could help you solve the issue.
Raeesa
RaeesaM_Intel
We haven't heard back from you and would no longer be monitoring this issue. Please raise a new thread if you have further issues.
Raeesa
