Analyzers
Advisor does not let my program read external files.
dominique120
I have a program that must read a configuration file when it starts but whenever I start this program inside advisor the program does not read this external configuration file. If I execute the program outside of advisor the program loads this file fine.
Is there something I can do so that my program reads the config file?
I had this problem with inspector and I fixed it by going to properties and changing the working directory but I cant find any properties dialog box.
Holly_W_Intel
Yeah, it is probably the same thing you saw with IXE, except IXE has somewhat more obvious project properties.
If you are using VS, you can find the Advisor project under "Project->Intel Advisor 2013 Project Properties".
Holly_W_Intel
dominique120
Its working now, thanks.
