Analyzers
5284 Discussions
Analyse Memory Consumption of an application
Claudio_K_Intel
I'm trying to analyse the memory consumption of our application with VTune Amplifier 2019, collected data and wanted to find out in the "bottom -up" timeline with "filtered in by selection"  for a peak all the memory which is at that point allocated by which function.
Is this possible or must i select all steps in the time line and sum that up? The total memory consumption is only be shown in the timeline or is it possible to get a more precise value?
thank you
Claudio
Dmitry_R_Intel1
Yes the bottom-up grid should provide you exactly this. The usual usage model for memory consumption is to select time region from the left to the peak (the right boundary of the region should be exactly on the peak, not after it) and then sort grid by allocation/deallocation delta to see what functions contributed the most to the memory growth.
Claudio_K_Intel
Thank you Dimitry,
for this info. The memory displayed in the "bottom-up" list and the graph is this the actual RAM used by App or is this the virtual memory which can also be located in a file if generated with mmap?
Cause linux time command shows less maximum set size compared to what i see in VTune.
thank you
Claudio
Dmitry_R_Intel1
This is all virtual memory that was allocated using API that VTune intercepts. Mmap is intercepted so yes this is possible.
Claudio_K_Intel
Thank you Dimitry for this clarification!
Is it possible to change this in the setup or is there a way to find out the maximum of the real RAM usage?
thank you
Claudio
