I've been attempting to run VTune 9.0u7 on a Fedora 8 (c2q 6600/em64t) machine. I installed the Fedora 7 kernel mentioned in the documentation (2.6.21-1.3194.fc7) and it appeared to be working fine.
After 2 days of use, the machine has hung twice running sampling that previously ran successfully on the exact same setup (syslog follows message). Would backing the kernel down to a pre-2.6.21 version (2.6.18-1.2798.fc6) help? Is there any way to get VTune working on Fedora 8?
Tom
Tom
May 20 17:31:46 xxxxx vtserver.bin: User "xxxxx" from "127.0.0.1" is executing application...
May 20 17:31:46 xxxxx kernel: VSD: [Warning] dsa_mmap: 1 != 3 = num_dsa_open
May 20 17:31:50 xxxxx vtserver.bin: sampling stopped ... processing data ...
May 20 17:31:50 xxxxx kernel: list_del corruption. next->prev should be ffff81022dd73000, but was ffff8101a5471800
May 20 17:31:50 xxxxx kernel: ------------[ cut here ]------------
May 20 17:31:50 xxxxx kernel: kernel BUG at lib/list_debug.c:72!
May 20 17:31:50 xxxxx kernel: invalid opcode: 0000 [1] SMP
May 20 17:31:50 xxxxx kernel: last sysfs file: /devices/pci0000:00/0000:00:00.0/irq
May 20 17:31:50 xxxxx kernel: CPU 3
May 20 17:31:50 xxxxx kernel: Modules linked in: appletalk ipx p8023 nvidia(P)(U) ipt_REJECT nf_conntrack_ipv4 xt_state nf_conntrack nfnetlink xt_tcpudp iptable_filter ip_tables x_tables vtune_drv(U) fuse rfcomm l2cap bluetooth sunrpc dm_mirror dm_multipath dm_mod ipv6 snd_hda_intel snd_hda_codec snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss snd_pcm snd_timer iTCO_wdt snd iTCO_vendor_support i2c_i801 parport_pc tg3 soundcore i2c_core snd_page_alloc parport sr_mod sg pcspkr serio_raw cdrom ata_piix ahci libata sd_mod scsi_mod ext3 jbd mbcache uhci_hcd ohci_hcd ehci_hcd
May 20 17:31:50 xxxxx kernel: Pid: 28027, comm: vtserver.bin Tainted: P 2.6.21-1.3194.fc7 #1
May 20 17:31:50 xxxxx kernel: RIP: 0010:[] [ ] list_del+0x3f/0x5b
May 20 17:31:50 xxxxx kernel: RSP: 0018:ffff8101d958fe48 EFLAGS: 00010286
May 20 17:31:50 xxxxx kernel: RAX: 0000000000000058 RBX: ffff81022dd73000 RCX: ffffffff8055a008
May 20 17:31:50 xxxxx kernel: RDX: ffffffff8055a008 RSI: 0000000000000092 RDI: 0000000000000000
May 20 17:31:50 xxxxx kernel: RBP: 0000000000003388 R08: ffffffff8055a008 R09: 0000000000000001
May 20 17:31:50 xxxxx kernel: R10: 0000000000000000 R11: ffffffff8059c000 R12: 0000000000000058
May 20 17:31:50 xxxxx kernel: R13: 0000000000000c78 R14: ffff8102359b8cc0 R15: 0000000000001000
May 20 17:31:50 xxxxx kernel: FS: 0000000043204950(0063) GS:ffff81023bce97c0(0000) knlGS:0000000000000000
May 20 17:31:50 xxxxx kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
May 20 17:31:50 xxxxx kernel: CR2: 00002aaaaabeb8c0 CR3: 000000012f5fc000 CR4: 00000000000006e0
May 20 17:31:50 xxxxx kernel: Process vtserver.bin (pid: 28027, threadinfo ffff8101d958e000, task ffff8101c1fea100)
May 20 17:31:50 xxxxx kernel: Stack: 0000000300000000 ffffffff882f400a 0000000043200c98 ffffffff882f4030
May 20 17:31:50 xxxxx kernel: 0000000043200c98 ffffffff882f4095 0000000000000246 ffffffff882f4909
May 20 17:31:50 xxxxx kernel: ffff8102359b8cc0 0000000000000000 ffff8102359b8cc0 0000000000004000
May 20 17:31:50 xxxxx kernel: Call Trace:
May 20 17:31:50 xxxxx kernel: [] :vtune_drv:remove_h ead_list+0x1a/0x30
May 20 17:31:50 xxxxx kernel: [] :vtune_drv:pop_mr_buf_from_head_of_out_list+0x10/0x30
May 20 17:31:50 xxxxx kernel: [] :vtune_drv:get_next_mr_rec_from_out_list+0x45/0x70
May 20 17:31:50 xxxxx kernel: [] :vtune_drv:samp_write_module_file_ex+0x89/0xb0
May 20 17:31:50 xxxxx kernel: [] :vtune_drv:samp_write_module_file+0x4e/0x160
May 20 17:31:50 xxxxx kernel: [] autoremove_wake_function+0x0/0x2e
May 20 17:31:50 xxxxx kernel: [] vfs_read+0xcb/0x173
May 20 17:31:50 xxxxx kernel: [] sys_read+0x45/0x6e
May 20 17:31:50 xxxxx kernel: [] tracesys+0xdc/0xe1
May 20 17:31:50 xxxxx kernel: Code: 0f 0b eb fe 48 89 48 08 48 89 01 48 c7 47 08 00 02 20 00 48
May 20 17:31:50 xxxxx kernel: RIP [] list_del+0x3f/0x5b
May 20 17:31:50 xxxxx kernel: vtserver.bin[28026]: segfault at 0000000000000000 rip 00002aaaacd2216b rsp 0000000042802ed0 error 4
May 20 17:31:51 xxxxx vtlistenerd[27603]: Killed.
May 20 17:31:52 xxxxx vtlistenerd[28302]: ======================================================
May 20 17:31:52 xxxxx vtlistenerd[28302]: VTune Performance Analyzer Remote Agent for Linux*
May 20 17:31:52 xxxxx vtlistenerd[28302]: Copyright (C) 2002-2007 Intel Corporation
May 20 17:31:52 xxxxx vtlistenerd[28302]: -- Remote Agent --------------
May 20 17:31:52 xxxxx vtlistenerd[28302]: server version: v9.0
May 20 17:31:53 xxxxx vtlistenerd[28302]: Incoming connection request: Session Id: 127.0.0.1-28295, User_Id: henretty, Client IP: 127.0.0.1 Arch:, Version: vt 9.0, protocol version 0.0
May 20 17:31:53 xxxxx vtlistenerd[28337]: Connection accepted
May 20 17:31:53 xxxxx vtserver.bin: -- Sampling Collector --------
May 20 17:31:53 xxxxx vtserver.bin: driver version: v0.9495
May 20 17:31:53 xxxxx vtserver.bin: library version: v0.879
May 20 17:31:56 xxxxx vtlistenerd[28302]: Incoming connection request: Session Id: 127.0.0.1-28295, User_Id: henretty, Client IP: 127.0.0.1 Arch:, Version: vt 9.0, protocol version 0.0
May 20 17:31:56 xxxxx vtlistenerd[28412]: Connection accepted
May 20 17:31:56 xxxxx vtserver.bin: -- Sampling Collector --------
May 20 17:31:56 xxxxx vtserver.bin: driver version: v0.9495
May 20 17:31:56 xxxxx vtserver.bin: library version: v0.879
May 20 17:31:56 xxxxx vtserver.bin: received request from henretty@xxxxx
May 20 17:31:56 xxxxx vtserver.bin: calibration run started ...
May 20 17:31:56 xxxxx vtlistenerd[28302]: Incoming connection request: Session Id: 127.0.0.1-/home/henretty/vtune/data/Projects, User_Id: henretty, Client IP: 127.0.0.1 Arch:, Version: vt 9.0, protocol version 0.0
May 20 17:31:56 xxxxx vtlistenerd[28490]: Connection accepted
May 20 17:31:56 xxxxx vtserver.bin: User "henretty" from "127.0.0.1" is executing application...
May 20 17:31:56 xxxxx kernel: VSD: [Warning] dsa_mmap: 1 != 2 = num_dsa_open
May 20 17:32:06 xxxxx kernel: BUG: soft lockup detected on CPU#0!
May 20 17:32:06 xxxxx kernel: Call Trace:
May 20 17:32:06 xxxxx kernel:[ ] softlockup_tick+0xd5/0xe7
May 20 17:32:06 xxxxx kernel: [] update_process_times+0x42/0x68
May 20 17:32:06 xxxxx kernel: [] smp_local_timer_interrupt+0x34/0x55
May 20 17:32:06 xxxxx kernel: [] smp_apic_timer_interrupt+0x43/0x5b
May 20 17:32:06 xxxxx kernel: [] apic_timer_interrupt+0x66/0x70
May 20 17:32:06 xxxxx kernel:[ ] _spin_lock+0x7/0xf
May 20 17:32:06 xxxxx kernel: [] :vtune_drv:samp_write_module_file_ex+0x25/0xb0
May 20 17:32:06 xxxxx kernel: [] :vtune_drv:samp_write_module_file+0x130/0x160
May 20 17:32:06 xxxxx kernel: [] vfs_read+0xcb/0x173
May 20 17:32:06 xxxxx kernel: [] sys_read+0x45/0x6e
May 20 17:32:06 xxxxx kernel: [] tracesys+0xdc/0xe1
May 20 17:32:06 xxxxx vtserver.bin: calibration stopped ... processing data ...
May 20 17:32:16 xxxxx kernel: BUG: soft lockup detected on CPU#3!
May 20 17:32:16 xxxxx kernel: Call Trace:
May 20 17:32:16 xxxxx kernel:[ ] softlockup_tick+0xd5/0xe7
May 20 17:32:16 xxxxx kernel: [] __do_softirq+0x55/0xc3
May 20 17:32:16 xxxxx kernel: [] update_process_times+0x42/0x68
May 20 17:32:16 xxxxx kernel: [] smp_local_timer_interrupt+0x34/0x55
May 20 17:32:16 xxxxx kernel: [] smp_apic_timer_interrupt+0x43/0x5b
May 20 17:32:16 xxxxx kernel: [] apic_timer_interrupt+0x66/0x70
May 20 17:32:16 xxxxx kernel:[ ] _spin_lock+0x7/0xf
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:samp_load_image_notify_routine+0x1c6/0x240
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:core_vma_for_process+0xdb/0x120
May 20 17:32:16 xxxxx kernel: [] thread_return+0x0/0xe8
May 20 17:32:16 xxxxx kernel: [] :ip_tables:ipt_do_table+0x2d7/0x309
May 20 17:32:16 xxxxx kernel: [] :nf_conntrack_ipv4:ipv4_confirm+0x48/0x4e
May 20 17:32:16 xxxxx kernel: [] :ext3:ext3_get_blocks_handle+0xbd/0x8fc
May 20 17:32:16 xxxxx kernel: [] free_poll_entry+0x11/0x1a
May 20 17:32:16 xxxxx kernel: [] do_select+0x445/0x462
May 20 17:32:16 xxxxx kernel: [] find_get_page+0x21/0x47
May 20 17:32:16 xxxxx kernel: [] :jbd:do_get_write_access+0x4c1/0x4f6
May 20 17:32:16 xxxxx kernel: [] :ext3:__ext3_journal_dirty_metadata+0x1e/0x46
May 20 17:32:16 xxxxx kernel: [] :jbd:__journal_file_buffer+0x125/0x21c
May 20 17:32:16 xxxxx kernel: [] :ext3:ext3_get_acl+0x63/0x30d
May 20 17:32:16 xxxxx kernel: [] __d_lookup+0xb0/0x100
May 20 17:32:16 xxxxx kernel: [] do_lookup+0x63/0x1ae
May 20 17:32:16 xxxxx kernel: [] dput+0x3c/0x123
May 20 17:32:16 xxxxx kernel: [] __link_path_walk+0xc4c/0xd9c
May 20 17:32: 16 xxxxx kernel: [] mntput_no_expire+0x1c/0x92
May 20 17:32:16 xxxxx kernel: [] link_path_walk+0xce/0xe0
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:core_enum_modules_for_process+0x65/0x90
May 20 17:32:16 xxxxx kernel: [] __down_read_trylock+0x3e/0x44
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:enum_modules_for_process_end+0x6b/0x90
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:enum_user_mode_modules_end+0x22/0x40
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:stop_sampling+0xa8/0x280
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:vtune_sampuserstop+0xe/0x20
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:vtune_ioctl+0x5b3/0xe70
May 20 17:32:16 xxxxx kernel: [] lock_kernel+0x2c/0x48
May 20 17:32:16 xxxxx kernel: [] :vtune_drv:vtune_open+0x9/0x20
May 20 17:32:16 xxxxx kernel: [] chrdev_open+0x155/0x184
May 20 17:32:16 xxxxx kernel: [] open_namei+0x2c6/0x64c
May 20 17:32:16 xxxxx kernel: [] chrdev_open+0x0/0x184
May 20 17:32:16 xxxxx kernel: [] __dentry_open+0x101/0x1aa
May 20 17:32:16 xxxxx kernel: [] do_filp_open+0x2a/0x38
May 20 17:32:16 xxxxx kernel: [] do_ioctl+0x55/0x6b
May 20 17:32:16 xxxxx kernel: [] vfs_ioctl+0x24e/0x267
May 20 17:32:16 xxxxx kernel: [] sys_ioctl+0x59/0x78
May 20 17:32:16 xxxxx kernel: [] tracesys+0xdc/0xe1
連結已複製
2 回應
