Analyzers
5320 Discussions
Aps doesn't work with speical application
oleotiger
I'm using oneapi 2021.1.1 on centos7.6.
I wanna profiling mpi application with aps but it works when I run wrf but fails when I run lammps.
So I tries to run the application locally.
When I run wrf independently without aps `./wrf`, there is normal output from wrf and it runs correctly. With aps `aps ./wrf`, there is normal output as well.
When I run lammps indenpendently without aps `./lmp -sf opt -in in.lj` , I can get normal output of lammps and it runs correctly.
When I run lammps indenpendently with aps `aps ./lmp -sf opt -in in.lj` , the output stucks at the start. I can only get:
WARNING: There is at least non-excluded one OpenFabrics device found,
but there are no active ports detected (or Open MPI was unable to use
them).  This is most certainly not what you wanted.  Check your
cables, subnet manager configuration, etc.  The openib BTL will be
ignored for this job.
  Local host: 6248r-node125
LAMMPS (5 Jun 2019)
There are vtune and aps processes:
root     40684 31718  0 15:36 pts/49   00:00:00 aps ./lmp -sf opt -in in.lj
root     40688 40684  0 15:36 pts/49   00:00:00 /opt/compiler/intel/oneapi/vtune/2021.1.1/bin64/vtune -q -collect mps -mrte-mode=native -data-limit=0 -finalization-mode=none -r /tmp/aps_temp_1804289392masterResult -- ./lmp
root     40715 40710  0 15:36 pts/49   00:00:00 ./lmp
But I cannot see any log from lammps. Normally it will run about 3~5s. But with aps It stucks at start  least 1min and I didn't wait for its ending and killed it.
Dmitry_P_Intel1
The issue might be related to https://community.intel.com/t5/Analyzers/APS-tool-from-VTune-s-package-loses-application-arguments/m-p/1231211#M19654 . Please follow the recommendation to use a wrapper script to workaround the aps issue with the app parameters.
Thanks & Regards, Dmitry
RaeesaM_Intel
Thank you for posting in Intel Analyzers Forum.
Could you please share a sample reproducer code and steps to reproduce?
Raeesa
oleotiger
'm running lammps  https://lammps.sandia.gov.
lammps (https://lammps.sandia.gov/tars/lammps-30Nov20.tar.gz) is compiled with FFTW https://github.com/FFTW/fftw3/archive/fftw-3.3.8.tar.gz  with gcc9.3.0
Workload is in.lj (https://lammps.sandia.gov/bench.html).
Normally, run it with `./lmp -sf opt -in in.lj`.
With aps it failed with no response `aps ./lmp -sf opt -in in.lj`
Dmitry_P_Intel1
RaeesaM_Intel
Hi ,
Is your issue resolved? Did you check it with the latest version Vtune 2021.2.0 as mentioned in https://community.intel.com/t5/Analyzers/APS-tool-from-VTune-s-package-loses-application-arguments/m-p/1231211#M19654 .
Please let us know the updates.
Raeesa
RaeesaM_Intel
Can you give us an update on this ? Is your issue resolved ?
Raeesa
RaeesaM_Intel
Thank you for accepting the solution. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Raeesa
