Analyzers
5341 Discussions
Assert failed while running Profiler 2020 Update 2
Mentopolis
while running our C++ application in Profiler 2020 update 2 we get in most runs a assertation. The program abort and no performance report is created. Without profiler no such error appears.
Assertion failed: thread_manager_impl:1332: (threads_count != (tpss_u32_t)(-1)) : . Please contact the technical support.
regards
  Markus
JananiC_Intel
Thanks for posting in Intel forums.
Please let us know the platform details so that we can try from our side.Also run the self checker script which is located in <install_dir>/bin64 .This script is used to validate your installation and system setup,so run this script and let us know the result.
Mentopolis
Computer is a Intel (R) Core (TM) I7-2760QM CPU with 2.40 Ghz
when running the checker script in Admin mode i get a Blue-Screen with "SYSTEM_SERVICE_EXCEPTION" .. in common i can run in Admin mode but sometimes i also get a bluenscreen when set samples lower than 10 ms
when running the checker in normal user mode i get :
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009-2019 Intel Corporation. All rights reserved.
Build Number: 610396
Instrumentation based analysis check
Example of analysis types: Hotspots with default knob sampling-mode=sw, Threading with default knob sampling-and-waits=sw
Collection: Ok
vtune: Warning: Hardware collection of CPU events is not possible on this system. Microarchitecture performance insights will not be available.
vtune: Warning: To collect microarchitecture performance insights, run the product as administrator.
Finalization: Ok...
Report: Ok
HW event-based analysis check
Example of analysis types: Hotspots with knob sampling-mode=hw, HPC Performance Characterization, etc.
Collection: Fail
vtune: Error: Cannot enable Hardware Event-based Sampling due to a problem with the driver (sep*/sepdrv*). Check that the driver is running and the driver group is in the current user group list. See the "Sampling Drivers" help topic for further details.
vtune: Error: To collect hardware events, run the product as administrator.
Example of analysis types: Microarchitecture Exploration
Collection: Fail
HW event-based analysis with uncore events
Example of analysis types: Memory Access
Collection: Fail
HW event-based analysis with stacks
Example of analysis types: Hotspots with knob sampling-mode=hw and knob enable-stack-collection=true, etc.
Collection: Fail
HW event-based analysis with context switches
Example of analysis types: Threading with knob sampling-and-waits=hw
Collection: Fail
The check observed a product failure on your system.
Review errors in the output above to fix a problem or contact Intel technical support.
Log location: C:\Users\mzajc\AppData\Local\Temp\vtune-tmp-mzajc\self-checker-2020.09.04_13.10.12\log.txt
the checker Tool output looks like this
Vinutha_SV
What analysis are you trying to run? Looks like SEP drivers are not installed. Please make sure the drivers are installed and then try H/W events based sampling collection.
Mentopolis
Just reinstall the software from scratch.. the same result as in the first comment. Are there custom steps needed for setup this driver ?
Vinutha_SV
Looking at the logs, it is clear that SEP driver is not installed and so h/w event based sampling is failing.
You can install SEP drivers on windows, please refer to below link:
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/set-up-analysis-target/windows-targets/installing-the-sampling-drivers-for-windows-targets.html
JananiC_Intel
We are forwarding your case to Subject Matter Experts.
Vinutha_SV
Can you please attach the logs and the result directory to work on the issue?
Vinutha_SV
Since I have not heard from you since 2 weeks, I will be closing this thread in next 2 days.
Mentopolis
sorry for the delay the first mail was gone into the Spam folder.
It seems to work after this steps. Even the hardware based sampling does not show an Bluescreen.
thank you for your support
Vinutha_SV
Good to know that. I will be closing this thread.
