Analyzers
5250 Discussions
Assertion `g_lsepAdapter != ((void *)0)' failed
daothanhtuan
Hi all,
I've been trying to use VTuneApi functions. I used very similiar code to this link: http://software.intel.com/en-us/articles/use-vtuneapi-in-your-code-to-profile-without-launching-vtunetm-analyzer/
My machine is intel Xeon 5660, Linux Redhat 2.16.18.
As I run the program (with the api attached to it), an error occured:
VTStartSampling: Assertion `g_lsepAdapter != ((void *)0)' failed.
Aborted
I used the 64 bit library (in /opt/intel/vtune/rdc/analyzer/bin/libVtuneApi.so ).
Can anyone tell me how to solve this problem please? I've been headache because of this.
Thanks in advance,
Tuan
Peter_W_Intel
This article is only workable on Windows* environment, not suitable for Linux*.
First at all, please check if vtune driver is loaded - lsmod | grep vtune
Use this article on Linux* environment - you have to comment out statement "VTStartSampling(&params)" and statement "VTStopSampling(1)". That means only VTResumeSampling() & VTPauseSampling() are used in your code.
Create new project / activity after launching vtlec, select your app (use VTResumeSampling & VTPauseSampling) as launched app. Before finishing Wizard, please set "Start with data collection paused" on.
I have verified it works after doing above changes. Again, 1) doing VTStartSampling on vtlec 2) When application terminates, sampling will be stoppedby vtlec.
Good Luck!
Regards, Peter
daothanhtuan
Thanks Peter,
Yes I googled this for a while and found out that removing VTStartSampling and VTStopSampling defenitely works as I tested this (this also means Ismode is on for Vtune).
To this end, these two APIs can not run in Linux enviroments? Or is there any solutions to make them work on Linux? Not only these two APIs don't work, VTBindResults doesn't.
Putting it another way, i don't want to use vtl or vtlec because i want to print the results of VTune at some particular points in my program, is there any way to do this?
Thanks a lot,
Tuan
Peter_W_Intel
Hi Tuan,
I'm glad that you can use APIs (Pause and Resume)on Linux* environment. I don't know why other APIs don't work on Linux*.
Results can only beviewed by VTune Analyzer GUI or vtl command, so youhave no way to print resultsin your program.
Regards, Peter
