Analyzers
5275 Discussions
Bandwidth Analysis doesn't work on Ubuntu
Zeyar_H_
I am using VTune Amplifier XE 2015 on Ubuntu 14.04 on an Intel Xeon machine. I can run Advanced Hotspots Analysis, but I wish to run Bandwidth to see the exact CPI and cache efficiencies. However, each time I run the Bandwidth analysis, it starts executing and before it gets to parsing/working on the dataset, it hangs and then the whole machine just hangs and I have to force restart the machine. Advanced Hotspots works fine. I am able to run both Advanced Hotspots and Bandwidth on Windows on the exact same machine, which means does Bandwidth Analysis not work on Linux and/or Ubuntu 14.04 specifically?
Thanks!
Peter_W_Intel
Recent product is VTune(TM) Amplifier XE 2015 Update 4, which supports Ubuntu* 14.04.
I think that it might be due to processor type - I remember that bandwidth analysis was not supported on Nehalem processor and early processors. Please try this feature on 3nd Core(TM) generation processors or late, for example, SandBridge processors.
Zeyar_H_
It's an Intel Xeon E5 v3 (Haswell), so bandwidth analysis should be supported. Plus I mentioned it's working correctly on windows on the exact same machine. It's only in Ubuntu that it's hanging the machine. (I have dual boot on that machine). Any other thoughts?
Peter_W_Intel
Asked data for investigating via private message.
Peter_W_Intel
For using Event-based sampling on Haswell EP, please use latest VTune Amplifier XE 2015 U4. Both Advanced-hotspots and bandwidth analysis worked well, verified by Zeyar H.
Ron_Green
what version of Vtune was hanging?
I'm seeing the same behavior with 2015.1.0.367959 - this on a Sandybridge running RHEL 6.6.  Hotspots are fine, memory analysis hangs.
We then tried 2015.2 and 2016 beta - both of these allow memory analysis to run to completion.
Is it safe to assume that 2015 Update 1 has a bug?
Ron
Peter_W_Intel
@Ron
Same problem when using 2015.2, using 2015.4 solved the problem.
Remember to use latest version which supports latest silicon & latest operation systems.
