Analyzers
5249 Discussions
Bandwidth Microarchitecture Analysis is not collecting data.
cole_b_
I am trying to familiarize myself with VTune Amplifier. I am attempting to run the "Bandwidth" test under "Microarchitecture Analysis". When I run it, the summary tab shows the "Elapsed Time" and the "Collection and Platform Info" section, but there is no "Average Bandwidth" section. When I go to the Bottom-up tab, the Bandwidth graph is empty. I assume it is not collecting memory data correctly.
This is running on Ubuntu 14.04 with the Silvermont Celeron J1900 chip. Is it because this cpu is not supported? Or am I misunderstanding what this test is supposed to do.
David_A_Intel1
Hi cole:
If the tool is not displaying a warning when you select the analysis type, it should be supported on the processor.
Questions: how long is the "elapsed time" reported by VTune Amplifier?  What version of VTune Amplifier are you using (output of 'amplxe-cl -version')?
cole_b_
The version is VTune Amplifier XE 2015 Update 4.1 (Build 412820). The elapsed time is 58.564s with a CPU time of 51.892s. If it matters, the hotspot test works as expected.
David_A_Intel1
okay, that release should support what you are trying to do.  However, let's verify that the VTune Amplifier drivers are loaded.  As root/sudo, cd to <install-dir>/sepdk/src and execute the command './insmod-sep3 -q'.
cole_b_
I ran the command both as sudo and default user. Both returned:
pax driver is loaded and owned by group "vtune" with file permissions "666".
sep3_15 driver is loaded and owned by group "vtune" with file permissions "666".
vtsspp driver is loaded and owned by group "vtune" with file permissions "666".
Ekaterina_L_Intel
Hello Cole B.,
Can you please verify several additional things, it will allow to figure out whether uncore events can be collected or not on your system:
From <vtune install dir>/bin64/ run:
1. >./sep -pmu-types
    You should see "sa" in the output
2. >./sep -el sa
    You should see "UNC_VISA_Memory_DDR_BW" in the outputed list
3. >./sep -start -d 10 -ec "UNC_VISA_Memory_DDR_BW"
     The collection should generate *.tb6 file
4. > ./amplxe-cl -import ./<the tb6 file>
    As result you should see a report with Uncore events collected. Something like below:
Uncore Event summary
Hardware Event Type                        Hardware Event Count:Self
UNC_VISA_Memory_DDR_BW.DDR_Chan0_Read32B                          57
UNC_VISA_Memory_DDR_BW.DDR_Chan0_Read64B                     5220544
UNC_VISA_Memory_DDR_BW.DDR_Chan0_Write32B                        234
UNC_VISA_Memory_DDR_BW.DDR_Chan0_Write64B                     822748
UNC_VISA_Memory_DDR_BW.DDR_Chan1_Read32B                           0
UNC_VISA_Memory_DDR_BW.DDR_Chan1_Read64B                           0
UNC_VISA_Memory_DDR_BW.DDR_Chan1_Write32B                          0
UNC_VISA_Memory_DDR_BW.DDR_Chan1_Write64B                          0
Please provide output from each of 1-4 commands below.
Regards, Katya
cole_b_
I attached the outputs because the formatting was too weird otherwise. FYI, for step 3 and 4, I had to use sudo for the command to work. Step 4 also produced a lot of the "Cannot locate debugging symbols for file '...'" warnings, but I've read that is normal. It seems I am getting all 0's in the "Hardware Event Count:Self" Column.
Ekaterina_L_Intel
Can you please make sure your system BIOS is configured to PerfMode as specified in this article:
https://software.intel.com/en-us/articles/SLM-SoC-uncore-performance-monitoring-guide
Enabling uncore monitoring
In order to sample uncore events, the feature must be enabled by BIOS/FW.  Indicators that the FW is not configured for uncore monitoring are:
  1. All events counts are zero
  2. System agent event counts correctly but all memory controller event counts are zero
On a platform enabled with BIOS menus, there may be a menu option to change "PDM/DFX" setting.  The desired setting is “PerfMode”.  Otherwise you must acquire a FW version with uncore monitoring enabled from your firmware provider.
If your BIOS does expose the PerfMode option, then it will likely be under a "Debug Configuration" menu
Katya
cole_b_
It appears that his setting is not available in my BIOS. I likely won't be able to get the right firmware, so I will look elsewhere for this type of benchmarking. Are the other tests that produce results still accurate without this setting? Is it specific to the Memory Bandwidth tests?
Ekaterina_L_Intel
Hello Cole B.
It's specific to Memory Bandwidth, as on Silvermont-based platforms it requires uncore monitoring enabled.
Algorithm analsysis and core profiling should work. Let us know if you see other issues.
Regards, Katya
