Analyzers
Based on QNX 7, when executing sep with option "p2", segfault error happens.
Lee__Hyungho
Hi
https://software.intel.com/en-us/vtune-cookbook-profiling-linux-and-qnx-system-boot-time#QNX
with Inter VTUNE user guide above on QNX, I want to get more datas necessary for analyzing processes running in target board with VTUNE Profiler. However, I found that  segmentation fault error happens in target board when typing "./sep -p2" to send call-stack datas to host PC.
 (refer to attached picture)
Environment of target board is with Intel Denverton and operating system QNX.
Environment of Host PC is with windows 7 and VTUNE Amplifier 2019 Update7
But, If executing sep without any options in target board , It works well. (ex typing only "./sep" and enter). and VTUNE Profiler can get datas from target board. (but there are not call-stack datas because not adding "-p2"
Why is the segfault error made when with QNX environment?
Best Regards
Jennifer_D_Intel
Unfortunately this is a known problem with QNX 7 and the -p option, and it is not planned to be supported in the near future.
ArunJ_Intel
Hi Lee,
We are forwarding this case for SME to check. Meanwhile could you please post the output of the below command to help us debug the issue
sep -version
Arun Jose
Jennifer_D_Intel
