Analyzers
Branch Monitoring
Marcus_B_
Hi, I'm Marcus, I'm doing an academic research on branch monitoring using Branch Trace Store capabilities. Currently, i'm trying to implement a BTS monitor on Windows 7/8. I'm facing some challenges on such development and so I ask for any help. I made a question on performance forum, but anyone was able to answer me, so I feel free to ask here, since Vtune uses BTS monitoring on Windows. I intend to count taken branches within under specific conditions, so I developed a device driver to be interrupted when my DS buffer is full (threshold defined). I set up DS area properly and BTINT flag on MSR. I checked: processor is already correctly filling my buffer. However, I don't know how to be interrupt properly. From what I understood, processor will generate the interrupt on APIC performance counter defined vector, which, in my case, is 254. I can't register a line interrupt on 254 IRQ once it is in use by Windows APIC. I can register other IRQ numbers, but, of course, i'm not interrupted (I tested it, just for confirmation). Any ideas of how to proceed would be very helpful Thanks in Advance
Marcus_B_
I finally registered my ISR routine, but I am not being interrupted. I am looking to see if my configuration is correct. I set DS MSR with the BTS structure, and I checked: addresses are correctly written. I set DEBUGCTL MSR with BTS, BTINT and LBR flags. Is is enough to generate the interruption ? Should I set something more, like MSR_PERF_GLOBAL MSR or other ? Thanks, Marcus
Dmitry_P_Intel1
Hello Marcus,
From VTune engineers we have the following output on the question you raised:
1.    DEBUGCTL should have TR, BTS, and BTINT (bits 6, 7, 8) set.
2.    Default Windows PMI vector (0xFE) can be hooked using this function:
HalSetSystemInformation(HalProfileSourceInterruptHandler, sizeof(void*), &handler);
3.    In case interrupts stop arriving after the first PMI, you should manually unmask APIC’s PMI LVT entry in your PMI handler by writing 0xFE to IA32_X2APIC_LVT_PMI MSR (0x834) or through APIC memory, depending on your CPU version.
Hope that helps,
Thansk & Regards, Dmitry
Marcus_B_
Really Helpful, Thanks a lot.
Maor_H_
Very helpful indeed.
But i have a problem with handler in:
since according to MSDN, handler should be a struct of type MCA_DRIVER_INFO. but when i do it, only the exception callback is called, and not my handler.
if i pass the handler directly (not via MCA_DRIVER_INFO), than i get INTERRUPT_EXCEPTION_NOT_HANDLED.
Marcus_B_
In fact I did not tested this yet, but would be great to know how to make it work!
Maor_H_
oh i see...
would be great to see how to make it work. up until now i only get BSODs :)
i wonder what am i missing with this handler...
