When building the driver on Debian Stretch I get: Options in brackets "[ ... ]" indicate default values that will be used when only the ENTER key is pressed. C compiler to use: [ /usr/bin//gcc ] Make command to use: [ /usr/bin//make ] Kernel source directory: [ /lib/modules/4.1.0-1-amd64/build ] rm -f *.o .*.o.cmd .*.o.d .*.ko.cmd .*.ko.unsigned.cmd *.gcno rm -f sep3_15.ko sep3_15.ko.unsigned rm -f sep3_15*x32_64-4.1.0-1-amd64smp.ko rm -f Module.symvers Modules.symvers *.mod.c modules.order Module.markers rm -rf .tmp_versions make[1]: Entering directory '/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/pax' rm -f *.o .*.o.cmd .*.o.d .*.ko.cmd .*.ko.unsigned.cmd *.gcno rm -f pax.ko pax.ko.unsigned pax-x32_64-4.1.0-1-amd64smp.ko rm -f Module.symvers Modules.symvers *.mod.c modules.order Module.markers rm -rf .tmp_versions make[1]: Leaving directory '/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/pax' make[1]: Entering directory '/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/vtsspp' make[2]: Entering directory '/usr/src/linux-headers-4.1.0-1-amd64' Makefile:10: *** mixed implicit and normal rules: deprecated syntax make[2]: Leaving directory '/usr/src/linux-headers-4.1.0-1-amd64' rm -f /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/vtsspp/vtss_autoconf.h make[1]: Leaving directory '/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/vtsspp' /usr/bin//make -C /lib/modules/4.1.0-1-amd64/build M=/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src LDDINCDIR=/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/../include LDDINCDIR1=/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/inc modules PWD=/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src make[1]: Entering directory '/usr/src/linux-headers-4.1.0-1-amd64' Makefile:10: *** mixed implicit and normal rules: deprecated syntax CC/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/lwpmudrv.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/control.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/cpumon.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/eventmux.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/linuxos.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/output.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/pmi.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys_info.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/utility.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/chap.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/gmch.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/core2.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/perfver4.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/corei7_unc.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_wbox.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/silvermont.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/pci.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/apic.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/pebs.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_gt.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_client_imc.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_ncu.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_pcu.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_ha.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_cbo.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_ubox.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_power.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_common.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_qpi.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_r3qpi.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_imc.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_r2pcie.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_irp.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_edc.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_cha.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/unc_sbox.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sepdrv_p_state.o CC /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/valleyview_sochap.o AS /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys64.o /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys64.S: Assembler messages: /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys64.S:117: Error: no such instruction: `save_all' /opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys64.S:143: Error: no such instruction: `restore_all' /usr/src/linux-headers-4.1.0-1-common/scripts/Makefile.build:299: recipe for target '/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys64.o' failed make[4]: *** [/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src/sys64.o] Error 1 /usr/src/linux-headers-4.1.0-1-common/Makefile:1400: recipe for target '_module_/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src' failed make[3]: *** [_module_/opt/intel/vtune_amplifier_xe_2016.1.0.424694/sepdk/src] Error 2 Makefile:146: recipe for target 'sub-make' failed make[2]: *** [sub-make] Error 2 Makefile:8: recipe for target 'all' failed make[1]: *** [all] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-4.1.0-1-amd64' Makefile:177: recipe for target 'default' failed make: *** [default] Error 2
This build error is a result of the 4.1 Linux kernel. If you can downgrade your kernel to 4.0, you will not have this problem. VTune Amplifier XE 2016 supports 4.0 and older kernels (see Release Notes).
We expect to release an update with support for 4.1 kernels in the near future (but we cannot publish a date, so please don't ask ;).
Just FYI, VTune Amplifier XE 2016 Update 1 is now available and adds support for Linux kernels 4.1, 4.2, and 4.3. More information about the release is available on the What's New page.
