I notice today this issue regarding sep driver, sep5:
./build-driver
C compiler to use: [ /bin/gcc ]
C compiler version: 13.2.0
Make command to use: [ /bin/make ]
Make version: 4.3
Kernel source directory: [ /lib/modules/6.8.0-36-generic/build ]
Kernel version: 6.8.0-36-generic
Cleaning workspaces ...
Done
Building socperf driver ...
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0
You are using: gcc (Ubuntu 13.2.0-23ubuntu4) 13.2.0
Skipping BTF generation for /opt/intel/oneapi/vtune/2024.2/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base+0x3: 'naked' return found in RETHUNK build
/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay+0x0: 'naked' return found in RETHUNK build
make[3]: *** [scripts/Makefile.build:361: /opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o] Error 254
make[3]: *** Deleting file '/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o'
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [/usr/src/linux-headers-6.8.0-36-generic/Makefile:1926: /opt/intel/oneapi/vtune/2024.2/sepdk/src] Error 2
make[1]: *** [Makefile:240: __sub-make] Error 2
make: *** [Makefile:224: default] Error 2
Failed to build the drivers
I reinstalled my machine with Ubuntu 24.04 LTS with default Canonical Kernel.
But sep driver is not build for this configuration.
OneAPI version: OneAPI 2024.2.x
VTune version: intel-oneapi-vtune - 2024.2.0-707
OS:
cat /etc/os-release
PRETTY_NAME="Ubuntu 24.04 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logoPackages from Canonical 6.8 Kernel.
dpkg -l | grep -E "linux-image|linux-headers"
ii linux-headers-6.8.0-28 6.8.0-28.28 all Header files related to Linux kernel version 6.8.0
ii linux-headers-6.8.0-28-generic 6.8.0-28.28 amd64 Linux kernel headers for version 6.8.0 on 64 bit x86 SMP
ii linux-headers-6.8.0-36 6.8.0-36.36 all Header files related to Linux kernel version 6.8.0
ii linux-headers-6.8.0-36-generic 6.8.0-36.36 amd64 Linux kernel headers for version 6.8.0 on 64 bit x86 SMP
ii linux-headers-generic-hwe-24.04 6.8.0-36.36 amd64 Generic Linux kernel headers
ii linux-image-6.8.0-28-generic 6.8.0-28.28 amd64 Signed kernel image generic
ii linux-image-6.8.0-36-generic 6.8.0-36.36 amd64 Signed kernel image generic
ii linux-image-generic-hwe-24.04 6.8.0-36.36 amd64 Generic Linux kernel image
链接已复制
2 回复数
Refer to the discussion about the same issue.
