Analyzers
5253 Discussions
Building sepdk on Linux kernel 6.1 fails.
Daniel_H
I'd just like to report that building sepdk driver on Linux kernel 6.1 does fail.
On LTS 5.15 it works perfectly.
Here is the output of the failing build attempt:
sudo ./build-driver -ni
[sudo] password for root:
C compiler version: 12.2.1
Make version: 4.4
Kernel version: 6.1.9-arch1-1
Cleaning workspaces ...
Done
Building socperf driver ...
Done
Building sep driver ...
/home/intel/oneapi_2023_0_0/vtune/2023.0.0/sepdk/src/linuxos.c: In function ‘linuxos_Enum_Modules_For_Process’:
/home/intel/oneapi_2023_0_0/vtune/2023.0.0/sepdk/src/linuxos.c:537:23: error: ‘struct mm_struct’ has no member named ‘mmap’
 537 |         for (mmap = mm->mmap; mmap; mmap = mmap->vm_next) {
/home/intel/oneapi_2023_0_0/vtune/2023.0.0/sepdk/src/linuxos.c:537:48: error: ‘struct vm_area_struct’ has no member named ‘vm_next’
make[2]: *** [scripts/Makefile.build:250: /home/intel/oneapi_2023_0_0/vtune/2023.0.0/sepdk/src/linuxos.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:2005: /home/intel/oneapi_2023_0_0/vtune/2023.0.0/sepdk/src] Error 2
make: *** [Makefile:215: default] Error 2
Failed to build the drivers
Rahila_T_Intel
Thanks for posting in intel communities.
Please be informed that Driverless Perf based collections on ADL is supported by Linux kernel since 5.15.5. Thats why you are facing issue when trying to building sepdk driver on Linux kernel 6.1, which is beyond 5.15.
Please refer the below link
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Rahila_T_Intel
Daniel_H
Thanks for your answer.
Indeed it works. It was quite a long time I didn't use vtune & co, and I was still trained to build and launch the driver.
Sorry for the nuisance.
Daniel
Rahila_T_Intel
Glad to know that your issue is resolved.
Thanks for accepting our solution.  If you need further assistance, please post a new question as this thread will no longer be monitored by Intel.
