Analyzers
5328 Discussions
Bus Utilization on Dual Processor Xeon
m_faulkner
Hey all,
I'm calcuating the bus utilization on a dual processor xeon machine (so i have 8 cores in total).
However, when i come to calcuate the Bus utilisation i get values of up to 200% (I'm assuming it's %)
I'm recorded the metrics as referenes in the vtune reference, i.e. BUS_TRANS_ANY.ALL_AGENTS and CPU_CLK_UNHALTED.BUS.
Does this seem correct? To me this seems wrong.
Any pointers will be great.
TimP
The CPU to bus clock speed ratio factors into this. VTune asks you to enter the CPU speed, but I think it guesses the bus speed. Also, if your formula uses a single socket bus capacity rating, that would be wrong for dual socket with balanced usage. If you get all the numbers right, you are unlikely to achieve even 80%.
m_faulkner
Quoting - tim18
Thanks for the reply.
How does vtune factor in the CPU to bus speed ratio? I'd like to understand the exact forumlae used.
TimP
Quoting - m.faulkner
Sorry, I may be thinking of some older machine. There surely is a lack of searchable references on this.
m_faulkner
Quoting - tim18
So we now think that the bus utilisation does use the ratio of bus speed / cpu speed? If so then i still don't understand why when i record the above metric i get a % utilisation of around 200%
m_faulkner
Having looked in to this, i'm now wondering if it has to do with the fact that i'm recording on all my cores? Therefore having a figure which (because i've got 8 cores) is x8 greater than it should be?
Any one any hints as to why i would have the BUS UTILIZATION > 100% (using the forumlae from the vtune docs)
