Analyzers
5254 Discussions
Calculating DRAM bandwidth from EMON
cnsujeer
I wanted to extract DRAM bandwidth information from EMON. For the same I extracted the following events:
  • UNC_M_CAS_COUNT_RD
  • UNC_M_CAS_COUNT_WR
And, then I used the below formula :
DRAM Bandwidth in GBps = (UNC_M_CAS_COUNT_RD + UNC_M_CAS_COUNT_WR) * 64 / 1GB / Time (sample window)
Is the above formula correct ? Especially using sampling duration as time ?
The reason I am asking is, Vtune shows for an application high bandwidth. But, if I run the same application through EMON and use the above formula.. I get very less bandwidth. (~8 times less). So, I was doubting if the formula being used is correct ?
Jennifer_D_Intel
I'm following up with the developers on your question, and will have an answer shortly.
cnsujeer
