Analyzers
5339 Discussions
Callgraph activity - with RDC
Yuval_Berger
We are currently working with the VTune 9.1 (for linux) and so far we created both call graph and sampling activities and are able to use RDC (remote data collector) running on our machine.
What I would like to do is to run my application (for example) for X hours and get some callgraph results for a few relavant periods in the test (each period in 5 minute sampling).
However, when using the vtune for this purpose, the call-graph activity requires (by definition) to launch an application.
This means that I will not be able to get a few call-graph in a single test without invoking the sampled application over and over again.
I tried to use the "pause" botton when running the activity - (which doesn't work flawlessly - sometimes the vtserver doesn't get the pause request from the client).
Anyways, the pause might provide with the ability to sample only the relevant parts of the test, but will result with a single "call graph result" instead of getting a result per each relevant part of the test.
Am I doing something wrong here?
Yuval Berger.
Peter_W_Intel
Quoting - Yuval Berger
Yuval Berger.
If you need to do Pause/Resume actions on remote Linux agent from the host, probably it will have delays on message communications between the host and the target. I suggest to use VTune APIs in your code instead of clicking buttons on GUI, refer to http://cache-www.intel.com/cd/00/00/21/93/219345_sampling_vtune.pdf from page 8.
Regards, Peter
