Analyzers
5255 Discussions
Can I see the result something like timeline-view in VTune?
Taehun_Kim
Hi, all.
The attached image is from nvvp.
I am wondering if I can see the profiling result like the attached image.
So I could see what function is used at certain time with timeline-view.
Thanks for answering in advance.
Egor_S_Intel1
It is possible but it depends on the application that you want to profile. If you profile the application that runs OpenCL kernels on GPU using "GPU Compute/Media Hotspots" analysis you will see OpenCL kernels on timeline and this feature works out of the box.
If you profile the application runs on CPU you can use Instrumentation and Tracing Technology (ITT) API.
