Analyzers
5285 Discussions
Can VTune 2017 work under Windows 10 VSM?
James_Byerly
I get an error about enabling vPMU, and I found some documentation that says hyper-v must be uninstalled, but I'm running windows 10 enterprise with VSM (virtualization-based security using hyper-v) and I'd really rather not disable this amazing leap in windows security if there is any way to get vtune working under this configuration.
Ekaterina_L_Intel
With enabled Hyper-V, VTune Amplifier will be able to collect only software-based data. You can try using Basic Hotspots, Concurrency, and Locks & Waits analysis.
Hardware based anslysis require PMU access and cannot be run under Hyper-V enabled.
Regards, Katya
