Analyzers
5253 Discussions
Can't identify nehalem CPU architecture on Windows
dwl1
I'm running VTune analyzer demo on a Windows 2008 Server (64-bit) box with dual X5570 (Core i7) Xeon processors.
Call graphing works fine, but sampling fails because it cannot identify the CPU architecture.
Is there a fix for this?
Peter_W_Intel
Quoting - dwl1
Are you sure that you are using latest product v9.1 Update 2?
If you already installed v9.1 Update 2, but can't find event ratios for Intel Core i7 processors - please read http://software.intel.com/en-us/articles/can-not-find-event-ratios-for-intelr-coretm-i7-processors/
Regards, Peter
dwl1
Hi Peter,
Thanks for replying.
I'm using the eval, downloaded two weeks ago. Help/About indicates is v9.0, so that's probably it. I think I've found the 9.1U2 download, I'll post back when it's installed/tested.
Dan
dwl1
This worked.
Just a note, I originally downloaded the Thread Profiler and was using the Vtune bundled therein ... the most recent threadf Profile bunder seems to contain an old version of VTune.
