Analyzers
5285 Discussions
Can't profile my threaded Application
r4dium
I have programmed a Win32 Application based upon DirectX9 and a video library called
FFMpeg with Visual Studio Team System 2008 under Windows Vista Business using MS C++ 9.0 .
When I try to profile the executable by Thread Profiler the following error message pups up:
"TP file not found. The target executable may have exited unexpectedly."
This correlates with the message vista gives me shortly before, which states that the program doesn't work any more.
It seems that something prevents my executable to start. If I simply double klick on it, it starts perfectly.
I am using the /Zi, /fixed:no and /MTd switches.
Regards R4DIUM
robert_c_3
Just one more data point - I am also getting this error on my home system - quad core system running Vista
I am usingIntel VTune Performance Analyzer 9.0
Build:719
Get the same error just trying to profile the primes example that comes in the Vtune TProfiler Smpales folder - This is much simpler reproducer if you can get it to work on Intel system on Vista as it only requiress the following dlls
Kernel32.dll
msvcr90d.dll
ntdll.dll
primesbalanced.exe
I have tried running VTune as administrator etc no luck
It just does not seem to create a tp file at all
The TP cahce folder is set to default here:
C:UsersbobAppDataLocalTempCacheTP_Cache
running Thread Profiler places several temp files here but NO TP file is created - I wonder if it is an over zealous Vista protection issue of some kind
Thoughts?
bobc
Found somewhat of workaround for simple Primes example in the VTune/TProfile/Samples folder based on suggestions above
COmpile project with Intel compiler using/Qtprofile switch
when application is run (I had to run as administrator) it creates tp.tp file
THen use Thread Profiler to open the tp.tp file as follows:
File->OpenFile (specify to look for fiels of type Intel Thread Profile (*.tp)) for the file type - navigate to where the application is run (that is where tp.tp is created by default)
Thread Profile date displayed fine for me on the simple Primes exmaple
Am now trying same approach on my "real" app - let you know if that works
BobC
robert_c_3
BobC
The work around above worked for me on my "real" app as well.
Compile w /Qtprofile & /MD (code generation, runtime library /MD)
Link w Fixed:no
build app
run app - this creates tp.tp & tp.tpd files
run Thread Profiler - do not run any activity here simply opent eh tp.tp file by using:
File->Open File->choose tp.tp (be sure to select file type as tp or else *.* or else you wont see tp.tp as a choice)
Then Thread Rpofiler showed data no problem
Hope this helps
BoB C
Mark_D_Intel
Quoting - r4dium
Regards R4DIUM
Build:719
Kernel32.dll
msvcr90d.dll
ntdll.dll
primesbalanced.exe
Thoughts?
bobc
What version of Thread Profiler are you using?
bsantana
I realized that there is a patch for Thread Profiler (tprofile3.1_010novpe_win.exe) in the net, so I just downloaded, installed it and is running once again the Thread Profiler. Thank you so much for your patiente and help.
Saludos
Benjamn Santana
sheshadri_manthascha
Hello;
i've got a similar issue..."Application failed to start 0x.... 5"
I'm building ffmpeg (from scratch) using Gcc-4.2.1-sjlj. FFmpeg is configured to shared (--enable-shared --disable-static). I've also disabled strip (not that this helps with MSVC).
The resulting dll's and libs are linked in with our app built in VS8 (i think i've got SP1) - this is a large system. OS is XP with SP3.
VTune ThreadProfiler is 3.1 (installed tprofile3.1_010novpe_win.exe).
First ThreadProfiler was not able find msvcr80d.dll; app runs fine from Explorer or command line.
** Seems to me that ThreadProfiler does not parse or use the manifest files **
So i copied the missing dlls into the default folder.
Now though it can find the dll's (no missing dll warning or error messages in output window), it still does not run.
trying to retool to Intel Compiler for this project i believe is major work and i've got some release bugs (threading related) that i need fix ASAP.
Any thoughts, help ?
- I believe that avutil is being used. how do i avert the symbol table issue alluded to previously in this thread ? our app needs to use avutil...
- are there specific compiler options that can be used w/GCC to prevent this ?
- are there any FFmpeg builds on Intel compiler ? Makefiles, project files that i could perhaps use to jumpstart the project ??
Any help is most appreciated.
Kindest regards,
Sheshadri
ooop!
I get the same error with trying to profile ffplay.exe (everything built using GCC) except that SDL.dll that ffplay loads is built in VS8.
S-
