Analyzers
5250 Discussions
Collecting call counts - possible with MPI?
Greg_S_1
Hello.  I am attempting to calculate estimated call counts using the command line instructions on this page: https://software.intel.com/en-us/articles/calculating-estimated-call-counts-with-intel-vtune-amplifier-xe-2013?language=ru. ; OS is RHEL 6.4 with kernel version 2.6.32-358.6.1.el6.x86_64.
My command line input is:  mpirun -n 2 amplxe-cl -collect lightweight-hotspots -r <results directory> -knob enable-stack-collection=true -knob enable-call-counts=true -- /opt/parallel/dev/v20150/cmx/impi_3.4.4/cmx QBV_TILT_Test2
Before the application starts to execute, this produces:
amplxe: Error: PMU resource(s) currently being used by another profiling tool or process.
amplxe: Internal Error
This error occurs even immediately after a system reboot.  The error does not occur when mpirun is not used.  Is there a workaround for this, or is this type of collection not supported when using MPI?
Thanks for any input.
TimP
You might consider collecting from one of the mpi processes.
Peter_W_Intel
Based one your command line, analysis type was "lightweight-hotspots" - which is not used in latest product. Please try 2015 version Update 1, collection type is "advanced-hotspots", note that you have to with option "-knob collection-detail=stack-and-callcount"
About message,
Was it possible that you ran prior collection but exited abnormally? The workaround is to 1. stop running vtune process. 2. unload/reload vtune drivers 3. uninstall/reinstall vtune drivers. about 2) & 3), please go vtune/sepdk/src to find utilities.
Another note is : don't run PMU event-based sampling collections on VM.
