Analyzers
Collection failed error
newport_j
What does it mean when you get the collection failed error. The total output is:
Collection failed.
Error: Binary file of the analysis target cannot be found. Please check the path or specify another path and try again.
I did check the path ands it seemdd correct. What is causing this error? Everrything seems where it should be.
Newport_j
Peter_W_Intel
You can verify in this way:
1. In console, ensure that application canrun smoothly without VTune Amplifier. (Does application call shared modules? You should specify LD_LIBRARY_PATH)
2. Use amplxe-cl to launch application and collect performance data
3. Run amplxe-gui from this console, the tool will inheritall system environment variables and user environment variables from the console
Regards, Peter
