Is it possible to produce output similar to perf script from a trace collected with Intel PT (with timestamps) in Linux command line?
Example perf commands:
perf record -e intel_pt// ls perf script --ns
Output:
ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffbcec2 dl_main (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffc6090 _dl_new_object (/lib/x86_64-linux-gnu/ld-2.27.so) ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffc60bc _dl_new_object (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffd92f0 strlen (/lib/x86_64-linux-gnu/ld-2.27.so) ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffd9329 strlen (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffc60c1 _dl_new_object (/lib/x86_64-linux-gnu/ld-2.27.so) ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffc60fc _dl_new_object (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffbaec0 calloc@plt (/lib/x86_64-linux-gnu/ld-2.27.so) ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffbaec0 calloc@plt (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffd55e0 calloc (/lib/x86_64-linux-gnu/ld-2.27.so) ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffd55f5 calloc (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffd55fc calloc (/lib/x86_64-linux-gnu/ld-2.27.so) ls 10068 [001] 385286.629487960: 1 branches: 7fc98ffd55fc calloc (/lib/x86_64-linux-gnu/ld-2.27.so) => 7fc98ffbaea0 malloc@plt (/lib/x86_64-linux-gnu/ld-2.27.so)
