Analyzers
5214 Discussions
Command-line resume option not valid for core2 event-based collections
jaj2276
[bash]
We want the ability to start profiling after X number of seconds while starting the profile from the command line. We can currently achieve this on the algorithmic-based collections (i.e. hotspots, concurrency, locks and waits) by passing in: -resume-after 60000 as an option to amplxe-cl However, whenever we run --collect core2_cycles-uops, it will not run if -resume-after 60000 is included. Is there a way to get these types of collections to only start after some period of time? // Works amplxe-cl --collect concurrency -follow-child -target-duration-type=short -no-allow-multiple-runs -no-analyze-system -data-limit=100 -slow-frames-threshold=40 -fast-frames-threshold=100 -resume-after 60000 --duration 300 -- /home/q/kewpie/current/bin/kewpie --app_instance=1 // Does not work amplxe-cl --collect core2_cycles-uops -follow-child -target-duration-type=short -no-allow-multiple-runs -no-analyze-system -data-limit=100 -slow-frames-threshold=40 -fast-frames-threshold=100 -resume-after 60000 --duration 300 -- /home/q/kewpie/current/bin/kewpie --app_instance=1 Unknown option: --resume-after Sampling collector options are incorrect; collection cannot continue. Please try again. // Works (notice we just removed the -resume-after 60000) amplxe-cl --collect core2_cycles-uops -follow-child -target-duration-type=short -no-allow-multiple-runs -no-analyze-system -data-limit=100 -slow-frames-threshold=40 -fast-frames-threshold=100 --duration 300 -- /home/q/kewpie/current/bin/kewpie --app_instance=1 [/bash]
Peter_W_Intel
I can repeat this problem with example from VTune Amplifier XE 2011.
[root@kentsfield-01 src]# cd /opt/intel/vtune_amplifier_xe_2011/samples/en/
[root@kentsfield-01 en]# ls
tachyon_vtune_amp_xe.tar.gz
[root@kentsfield-01 en]# tar xzf tachyon_vtune_amp_xe.tar.gz
[root@kentsfield-01 en]# make
tbbforexamples/2.2/set_tbb_symlinks.sh
check_for_valid_platform
amplxe-cl -collect concurrency -resume-after 5000 -duration 30 -- ./tachyon_analyze_locks
It works!
amplxe-cl -collect core2_cycles-uops -resume-after 5000 -duration 30 -- ./tachyon_analyze_locks
It reported, "Unknown option: --resume-after", "Sampling collector option are incorrect"
I will submit this problem to engineering team, and re-post the solution on this thread. Thanks for your valuable report.
Regards, Peter
Mark_D_Intel
The -resume-after option is unfortunately not working with any of the analysis types based on hardware event sampling.
A workaround is to use the -start-paused option, and then run amplxe-cl with the '-command resume' option after the desired delay.
The sequence of commands as a bash script:
#!/bin/sh
amplxe-cl -collect core2_cycles-uops -start-paused &
sleep 60
amplxe-cl -command resume
wait
Peter_W_Intel
Thanks Mark!
Another workaround is to start data collection in pause mode; Insert Pause/Resume API in users code, see this article.
The user has to use "-duration xxx" in , since there is no Stop API which can be inserted in users code.
Peter_W_Intel
However supporting option "-resume-after" for PMU event based sampling still is a new feature request for the product.
zamin78
Hi Mark,
I've tried the amplxe-cl -command resume but returning this message:
Fatal error: Cannot detect running collection to deliver command.
What I've did is:
#!/bin/bash
amplxe-cl -collect=locksandwaits -start-paused &
sleep 60
wait
Is there any way I could decide when to start the sampling and when to stop? I prefer not using user-controlcode APIs.
Dongwon
Peter_W_Intel
Since "resume-after" option can work on user-modedata collections (hotspots, concurrency, locksandwaits), there is no necessary to use "start-pause" in command line.
Here is example and its output from my side:
[root@NHM02 ~]# amplxe-cl -collect lightweight-hotspots -start-pause -duration 60 &
[1] 19989
[root@NHM02 ~]# amplxe-cl -command resume &
[2] 20025
[root@NHM02 ~]# Sampling successfully resumed.
1> The sampling collection paused.
1> The sampling collection resumed.
1>
Using result path `/root/r014lh'
Executing actions 75 % Generating a report
Summary
Elapsed Time: 44.669
Executing actions 100 % done
[1]- Done amplxe-cl -collect lightweight-hotspots -start-pause -duration 60
[2]+ Done amplxe-cl -command resume
By the way, if you don'tuse APIs in code to control, so you use sleep to know whento start and use duration to know when to stop.
Regards, Peter
