Analyzers
5320 Discussions
Comparison report not matching function names
Jon_K_
When I compare 2 results sets the comparison report (bottom-up) just contains duplicates for most of the functions with 0 time in alternate columns.  Basically it is not matching the functions from the 2 runs.
The 2 runs are with slightly different executables but they are essentially 99.9% the same.  Any hints on why VTune is not identifying the functions as being the same?
Jon
Dmitry_P_Intel1
So you can add "-group-by=source-function" to your command line report, or change grouping in grid to "Source function":
Thanks & Regards, Dmitry
James_S
Hi Jon,
Here is the guideline of  VTune for the result comparison:
 Binary recompiled: compare based on source function
 Changes inside a function: compare based on functions level
 Functions changed: source files level
 Source files changed: compare by modules
Zhuowei
Dmitry_P_Intel1
Jon_K_
Thanks Dmiitry,
Selecting "Source function / Function / Call Stack" as the grouping works.  I did try some of the groupings before but obviously missed this one.
Jon
