Analyzers
Configuring PDB files
scott_summers
I am using an evaluation version of VTunes and I am trying to figure out how to configure the tool to point at the right symbol files. There seems to be a default set of ISM files (not sure what they are) that the tool points to, and it does prompt you during analysis of a sample run for symbol references, but I want to know if there is a way to simply point to a single directory.
Any help would be greatly appreicated.
David_A_Intel1
Yes, there is. See the Options dialog, under Directories tab. Specify File type of Symbols, and then add one or more directories. Notice that you can specify a recursive search via the check box in the lower right. Select the directory, after adding it, and then you can check the box.
