Analyzers
5281 Discussions
Does Inspector XE work with TBB application?
missing__zlw
It seems Valgrind doesn't work with TBB memory allocator.
How about Inspector XE? Does it detect problem using TBB memory allocators? Not false violation report?
Do I need to turn on some special settings? I am working on Linux.
Any examples on using Inspector XE with TBB application?
Kirill_R_Intel
Yes, Intel Inspector XE supports TBB memory allocator, it should work without special settings.
Kirill
Peter_W_Intel
I just wrote a simple tbb example, which used scalable_malloc() and forgot to use scalable_free()
[cpp]#include
#include
#include "tbb/scalable_allocator.h"
#define LEN_STR 1024
using namespace tbb;
int main()
    char *str = (char *)scalable_malloc(LEN_STR*sizeof(char));
    strcpy (str, "This is an example to use tbb scalable");
    printf ("%sn",str);
    // Forget to do "scalable_free"
    return(1);
[/cpp]
#source /opt/intel/composer_xe_2011_sp1.7.256/bin/compilervars.sh intel64
# icpc -g tbb_scalable.cpp -ltbb_debug -ltbbmalloc -o tbb_scalable
# source /opt/intel/inspector_xe_2011/inspxe-vars.sh
Copyright (C) 2009-2011 Intel Corporation. All rights reserved.
Intel Inspector XE 2011 (build 186554)
# inspxe-cl -collect mi3 -module-filter-mode=include -module-filter=tbb_scalable -- ./tbb_scalable
Used suppression file(s): []
1 new problem(s) found
1 Memory leak problem(s) detected
# inspxe-cl -report problems
Problem P1: Error: Memory leak
/home/peter/tbb_scalable.cpp(12): Error X3: P1: Memory leak: Allocation site: Function main: Module /home/peter/tbb_scalable
You can see one memory leak detected, allocation site is at source line #12.
So Inspector XE can detect problem using TBB memory allocators.
Regards, Peter
SergeyKostrov
Valued Contributor II
Quoting zlw
If you have TBB v4.xinstalled on your system please take a look at \Examples folder. There are
24 test applications in the folderand anytest applicationcan be used with Inspector XE.
Sergey
missing__zlw
Great. Thanks.
