Analyzers
5315 Discussions
Download Intel Advisor for mac OS
Cielo__Salvatore
Hello, I just wanted to report that the download of Advisor standalone for mac OS is in the wrong place.
https://registrationcenter.intel.com/en/products/
There seems no macOS download, but when you select linux you may choose between a tar.gz and a .dmg that works on mac.
I think the dmg is in the wrong place. It was very hard to find it like this, so I thought I'd report it.
fjwillemsen
Thank you so much. I couldn't find it anywhere.
Kirill_R_Intel
Thanks for your report! We've restructured downloads layout, macOS viewer is now on the same level with Linux and Windows. Please check: https://registrationcenter.intel.com/en/products/
llodds
Hi, I can't find advisor for maxOS either. Now it only has linux and windows builds.
Andrey_K
Try this https://registrationcenter.intel.com/en/forms/?productid=3216
Select Linux\Windows, than select version, and download "dmg". Direct link to 2020 Initial Release Version is http://registrationcenter-download.intel.com/akdlm/irc_nas/tec/16211/advisor_2020.dmg
llodds
Thanks. I got it now. I need to select version "2020 initial release" or earlier versions in order to see the dmg.
Kirill_R_Intel
The macOS download was added on the same level as Windows and Linux. Is your license for Parallel Studio? You should see downloads as below. If you don't, can you submit a support ticket? And provide your license number there to check, if there is any issue with given configuration.
atyab191
Hi! I am still unable to see the option for MacOS. Please see the attached screenshot.
Also, is Advisor for macOS host-only? I thought it was possible to actually run and use on macOS, unlike VTune.
JyotsnaK_Intel
Thanks for raising this issue. It is resolved and available in the registrationcenter.intel.com as "Intel Advisor for macOS - host only". Please check the attached screenshot below:
Please let me know if you are able to download it. If yes, then please confirm if we can close this thread.
Thank you!
atyab191
Hello!
Thanks for your response. I was indeed able to download it. However, one more thing if I may: unlike the Linux distribution, there is no option/drop-down menu to choose the version of Advisor for macOS. (The option is there for VTune.)
Thanks again!
Jennifer_D_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
