Analyzers
5317 Discussions
Can not launch intel VTune Profiler 2020 in macOS 11.1
Yingkai
Hello, guys!
I found that I cannot launch profiler on my mac, the app closes immediately.
This is what I found in the console.
Feb 4 15:33:55 luanyingkai com.apple.xpc.launchd[1]: Coalition Cache Hit: app<application.com.intel.vtune.12048000.12051919(501)> [88909]
Feb 4 15:33:56 luanyingkai VTune Helper[47608]: getattrlist failed for /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver: #2: No such file or directory
Feb 4 15:33:56 luanyingkai VTDecoderXPCService[47610]: getattrlist failed for /Library/GPUBundles/AppleIntelKBLGraphicsVADriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsVADriver: #2: No such file or directory
Feb 4 15:33:56 luanyingkai VTDecoderXPCService[47610]: getattrlist failed for /Library/GPUBundles/AppleIntelCFLGraphicsVAME.bundle/Contents/MacOS/AppleIntelCFLGraphicsVAME: #2: No such file or directory
Feb 4 15:33:56 luanyingkai VTEncoderXPCService[47611]: getattrlist failed for /Library/GPUBundles/AppleIntelKBLGraphicsVADriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsVADriver: #2: No such file or directory
Feb 4 15:33:56 luanyingkai VTEncoderXPCService[47611]: getattrlist failed for /Library/GPUBundles/AppleIntelCFLGraphicsVAME.bundle/Contents/MacOS/AppleIntelCFLGraphicsVAME: #2: No such file or directory
Any help is appreciated, thank you very much!
Yingkai
David_K_5
I am using the latest Big Sur (version11.2.1) with the latest version of the oneAPI HPC Toolkit (2021.1), and I do not have any problems running the VTune  gui app from the command line.
Before using, I source the script:  ... oneapi/vtune_profiler/latest/env/vars.sh
Then from the command line, I run "sudo vtune-gui".
David
JananiC_Intel
Thanks for posting in Intel forums.
We are forwarding the case to SME.
Janani Chandran
Yingkai
Hi JananiC:
I just downgraded my Mac to Catalina, now I can launch VTune Profiler. But still looking forward to the solution for Big Sur.
Thank you very much.
Yingkai
David_K_5
David
Yingkai
Hi David,
Thank you for your help! I just tried what you said, it works now.
Yingkai
