Analyzers
5248 Discussions
Error: 0x40000025 (Inapplicable report), 0x40000024 (No data) -- No data is collected.
liu__kevin
When I run gobmk, it occurs error at last, does anyone knows this? it said:
runspec finished at Mon Sep 26 11:51:23 2016; 309 total seconds elapsed
amplxe: Collection stopped.
amplxe: Using result path `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk'
amplxe: Executing actions  0 %
amplxe: Warning: The result contains a lot of raw data. Finalization may take a long time to complete.
amplxe: Executing actions 14 % Loading 'systemcollector-3720-Tower.sc' file
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T103410.1506640.tb7' ().
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T103919.8394251.tb7' ().
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T104429.9108762.tb7' ().
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T104939.4509173.tb7' ().
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T105449.0449694.tb7' ().
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T105959.3802145.tb7' ().
amplxe: Error: Cannot load data file `/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/data.0/sep7fef03fe8700.20160926T114614.7910236.tb7' ().
amplxe: Executing actions 100 % done
amplxe: Error: 0x40000025 (Inapplicable report) -- The report 'summary' is not applicable to the result /home/foo/intel/MyAmplifierProjects/intel_test3/gobmk/gobmk.amplxe.
amplxe: Executing actions  0 % done
amplxe: Error: 0x40000024 (No data) -- No data is collected. Possible reasons:
 - Workload is too small. No samples are collected.
 - The application environment is not specified correctly.
But it runs others like astar, it works well.
Thank you.
Dmitry_P_Intel1
It looks like sampling collection trace is incomplete or broken since it cannot be loaded.
Several questions to have more details:
Is it 100% reproducible?
Do you have enough disk space for the trace? Please note that the elapsed time is quite substantial. You can try to limit the collection result size with a particular value using -data-limit collection option to check if it can be a potential reason.
Could you please provide VTune command line that you used?
What VTune version did you use?
Thanks & Regards, Dmitry
liu__kevin
Hi Dmitry,
Thank you for this reply. this is the command line I use:
/opt/intel/vtune_amplifier_xe_2016/bin64/amplxe-cl --collect newtest -follow-child -target-duration-type=short -allow-multiple-runs -no-analyze-system -data-limit=100 -result-dir=/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk  -- /home/foo/SPEC/QUN/SPEC/cpu2006/scripts/rungobmk
/opt/intel/vtune_amplifier_xe_2016/bin64/amplxe-cl -report summary -format csv -result-dir=/home/foo/intel/MyAmplifierProjects/intel_test3/gobmk > /home/foo/intel/MyAmplifierProjects/intel_test3/gobmk.csv
The vtune version is 2016 update4.
Thank you.
Dmitry_P_Intel1
Hello Kevin,
I would advise to have either -allow-multiple-runs option or -data-limit option in your command line.
Since your application is 300s of elapsed time and data limit is 100MB it most likely triggered on the first run and in this case VTune has some unexpected behavior (we will look at this). The data limit (if triggered) will anyway not allow you to collect statistics for events in all groups and this can be misleading.
liu__kevin
Hello Kevin,
Hi Dmitry,
I have removed -data-limit option and testing.
Thank you.
liu__kevin
Hello Kevin,
Hi Dmitry,
I got the result, thank you so much for your help.
Have a great night.
liu__kevin
Hello Kevin,
Hi Dmitry,
I have achieved the results, but I do not know how is going on with it, because the results seems like not correct, for example, I have tested the SPEC CIN2006 BENCHMARK like ASTAR and BZIP2, the results of INST_RETIRED.ANY and INST_RETIRED.ANY_P should be same or similar, but in my results, they are not same. So, do you know what is this problem? or how to explain this if correct.
ASTAR: INST_RETIRED.ANY_P/INST_RETIRED.ANY=0.14285263744119
BZIP2: INST_RETIRED.ANY_P/INST_RETIRED.ANY=0.14285333881443
Thank you.
