Analyzers
5338 Discussions
Error 0x40000026 (Database interface error)
ido_z_
Hi all.
I saw this on appeared in many cases but I did not see any resolution.
I am working with 2013 update 8, collecting on a remote machine and copying the results for the GUI stuff.
I am trying to run lightweight hotspots analysis with stacks and can not.
working without stacks is successful:
This is why I think all my drivers are working fine.
# ./amplxe-cl -collect lightweight-hotspots --duration 10
amplxe: Warning: On some systems based on the Intel microarchitecture code name Nehalem / Westmere with C-states enabled, this analysis type may cause system hanging due to a known hardware issue (see errata AAJ134 in http://download.intel.com/design/processor/specupdt/320836.pdf). To avoid this situation, disable all "Cn(ACPI Cn) report to OS" BIOS options before sampling with VTune Amplifier on such systems.
amplxe: Using result path `/disk/Alteon/vtune_amplifier_xe_2013/bin64/r000lh'
amplxe: Executing actions 16 % Resolving module symbols
amplxe: Warning: Cannot locate file `/boot/vmlinuz-2.6.34.14'.
amplxe: Executing actions 17 % Resolving information for `ld-2.5.so'
amplxe: Warning: Cannot locate symbols for file `/lib64/ld-2.5.so'.
amplxe: Executing actions 50 % Generating a report
Collection and Platform Info
Parameter                 r000lh
Application Command Line
Computer Name             nas
Environment Variables
MPI Process Rank
Operating System          2.6.34.14
Result Size               1477331
User Name                 root
CPU
Parameter          r000lh
Frequency          2400000000
Logical CPU Count  8
Name               Intel(R) Xeon(R) / Core i7 980X Processor
Summary
Elapsed Time:  9.845
CPU Usage:     0.000
Event summary
Hardware Event Type      Hardware Event Count:Self  Hardware Event Sample Count:Self  Events Per Sample
CPU_CLK_UNHALTED.THREAD  214000000                  107                               2000000
INST_RETIRED.ANY         170000000                  85                                2000000
CPU_CLK_UNHALTED.REF_P   17900000                   179                               100000
amplxe: Executing actions 100 % done
however trying to add stack collection causes this db issue:
first I can see that this makes me add a pid to attach to (why?, can't I do this system wide?)
when adding the pid and the request for stacks I get the failures and the .tb6 file is not generated.
When I try to open this in the GUI it fails.
# ./amplxe-cl -collect lightweight-hotspots --duration 10 -knob enable-stack=true -target-pid 3594
amplxe: Using result path `/disk/Alteon/vtune_amplifier_xe_2013/bin64/r001lh'
amplxe: Executing actions 24 % Processing profile metrics and debug information
amplxe: Warning: Error 0x40000026 (Database interface error) -- Cannot run data transformation `Compute CPU Usage'.
Parameter                 r001lh
Computer Name             nas
MPI Process Rank
Result Size               1014834
User Name
CPU
Parameter          r001lh
Frequency
Logical CPU Count  8
Summary
Elapsed Time:  0.000
Any help will be appreciated.
Thanks in advance.
Bernard
Valued Contributor I
>>>amplxe: Warning: Error 0x40000026 (Database interface error) -- Cannot run data transformation `Compute CPU Usage'.>.>
This was already discussed in previous threads.
ido_z_
Hi.
Thanks for the response.
I did see the discussion in other threads, but I could not see any resultion the the discussion.
Bernard
>>>I did see the discussion in other threads, but I could not see any resultion the the discussion.>>>
Sorry for late answer.
Regarding the results of the discussion I think that database error issue can be solved by VTune devs and we only can speculate about the possible culprit.
