Analyzers
5288 Discussions
Error: Internal error while resolving the results file.
Hariharasubramanian_
I am able to successfully profile applications on Fedora Core 6. However, for some applications, I get the following error:-
Mon Jun 4 13:34:59 2007 Error - Internal error while resolving the results file.
Mon Jun 4 13:34:59 2007 WARNING: no module of interest was loaded during activity
Any clues?
-- Hari
aokunev
Hello
Can you please submit this problem to the Premier tracker. Seem this is a program issue and should be fixed by engineering. Please provide details about your environment and test case of a problematic application if possible.
regards, Andrei
lvhv
I have exactly the same problem with my application. Should I submit the problem to the premier tracker or maybe there is a solution already. I think the only complex in my application is that it is multithread, I also has another more complex application and vtune works.. thanks in advance for any help.
