Analyzers
5285 Discussions
Error happend when use reverse proxy in vtune-backend.
mpi_new_user
New Contributor II
I can open the vtune-backend web interface with reverse proxy successfully after getting the param : --url-path-prefix .
And now some errors happened.
When I create a new project, the page will not display correctly. And 404 error will be happened in the network.
The  command  I used is :
vtune-backend --allow-remote-ui --enable-server-profiling --data-directory=/home/hpcadmin/test_dev/vtune_work --web-port=18080 --url-path-prefix=/dev/vtune/
###The folder <vtune_work> is empty!!!
Please let me know if I'm missing something.Thanks.
Gopika_Intel
Thank you for posting in Intel Communities. Since this is a duplicate thread of https://community.intel.com/t5/Analyzers/Error-happend-when-use-reverse-proxy-in-vtune-backend/m-p/1309284#M21222 , we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Gopika
