Analyzers
Error using Vtune
Mondal__Deepankar
I am trying to use Vtune and get the following error. There isnt any trace that would help me investigate this. Any pointers about how to investigate / fix this? Fwiw the error being returned appears to correspond to http://support.microsoft.com/kb/185294 and http://blogs.msdn.com/b/oldnewthing/archive/2010/07/30/10044061.aspx
Analysis started for C:\Windows\SysWOW64\cmd.exe (pid = 5732)
Loaded module: C:\Windows\SysWOW64\btpload32.dll, address range [0x02710000-0x0272CFFF]
Loaded module: C:\Windows\SysWOW64\cmd.exe, address range [0x4A140000-0x4A18BFFF]
Loaded module: C:\Program Files (x86)\Intel\Inspector XE 2013\bin32\ccrt12.dll, address range [0x56000000-0x56120FFF], minimal analysis
Loaded module: C:\Windows\syswow64\CRYPTBASE.dll, address range [0x74C30000-0x74C3BFFF]
Loaded module: C:\Windows\syswow64\SspiCli.dll, address range [0x74C40000-0x74C9FFFF]
Loaded module: C:\Windows\syswow64\USER32.dll, address range [0x74E80000-0x74F7FFFF]
Loaded module: C:\Windows\syswow64\ADVAPI32.dll, address range [0x75D30000-0x75DCFFFF]
Loaded module: C:\Windows\syswow64\RPCRT4.dll, address range [0x75FB0000-0x7609FFFF]
Loaded module: C:\Windows\syswow64\GDI32.dll, address range [0x762A0000-0x7632FFFF]
Loaded module: C:\Windows\syswow64\msvcrt.dll, address range [0x76430000-0x764DBFFF]
Loaded module: C:\Windows\syswow64\PSAPI.DLL, address range [0x764E0000-0x764E4FFF]
Loaded module: C:\Windows\syswow64\KERNELBASE.dll, address range [0x76580000-0x765C6FFF]
Loaded module: C:\Windows\syswow64\USP10.dll, address range [0x76680000-0x7671CFFF]
Loaded module: C:\Windows\system32\IMM32.DLL, address range [0x767B0000-0x7680FFFF]
Loaded module: C:\Windows\SysWOW64\sechost.dll, address range [0x768C0000-0x768D8FFF]
Loaded module: C:\Windows\syswow64\MSCTF.dll, address range [0x76B00000-0x76BCBFFF]
Loaded module: C:\Windows\syswow64\kernel32.dll, address range [0x76BD0000-0x76CDFFFF]
Loaded module: C:\Windows\syswow64\LPK.dll, address range [0x770B0000-0x770B9FFF]
Loaded module: C:\Windows\SysWOW64\ntdll.dll, address range [0x770E0000-0x7725FFFF]
Loaded module: C:\Windows\SysWOW64\SYSFER.DLL, address range [0x738D0000-0x7393CFFF]
Loaded module: C:\Windows\system32\WINBRAND.dll, address range [0x70E00000-0x70E06FFF]
Error: Internal error. Please contact Intel customer support team.
Application exit code: -529697949
Result file: C:\Temp\Inspector\Projects\athena2\r000mi1\r000mi1.inspxe
Analysis completed
Peter_W_Intel
Did you work on latest Update 14? Can this problem be repeated for every run? What was exact data collection type you did?
Usually exception occurred, VTune GUI provides "Send report" option to report problem to support team. In command line, use:
amplxe-feedback -create-bug-report <report archive>
amplxe-feedback -send-crash-report  <report archive>
You also can submit an issue to Intel Premier, with bug report archive.
Bernard
Valued Contributor I
>>>Application exit code: -529697949 >>>
It doess not look like Windows system error code.It could be VTune hardcoded error value.
Bernard
@Deepankar
Please disregard my post.I gave you an answer in Inspector XE forum.
Vitaly_S_Intel
According to IXE forum the problem was related to Symantec Endpoint Protection.
There shouldn't be collection problems using recent Symantec EP versions? Are you using some old one?
